Jump to content
Problems with DD
  • Please log in to reply
5 replies to this topic
#1 of 6 OFFLINE   Buckethead78
Buckethead78
  • 74 posts
Posted September 20 2008 - 12:19 PM
I just hooked up my new HK 254 yesterday. Everything seems to work, with one exception. My Xbox sends the signal through optical cable that DD is present(according to the receiver), but there is no sound! My other sources seem to work fine. Might this be as simple as a bad cable?
#2 of 6 OFFLINE   Ed Moxley
Ed Moxley
  • 2,701 posts
  • Real Name:Ed
  • LocationEastern NC
Posted September 20 2008 - 12:44 PM
So, you have set the Xbox to output the audio as "Bitstream", or "Raw"? It could be the cable. If you unplug the cable from the back of the receiver (still plugged into Xbox), can you see a red light in the end of the cable? Just a glance.........don't let the laser stay in your eyes.
Samsung HL61A750 (LED DLP)            Onkyo TX-SR805
Oppo BDP-83 Blu ray                                  Polk Audio LSi9
Polk Audio LSiC                                  Sony SS-MB100H
SVS PC12-NSD (Sub)                       ...
#3 of 6 OFFLINE   Buckethead78
Buckethead78
  • 74 posts
Posted September 20 2008 - 02:25 PM
I can see a light in the cable. I should clarify, it is an Xbox 360, and output is set to DD in the audio settings.
#4 of 6 OFFLINE   Joseph DeMartino
Joseph DeMartino
    Lead Actor
  • 8,308 posts
  • Real Name:Joseph DeMartino
  • LocationFlorida
Posted September 21 2008 - 12:04 AM
Did you configure the input on the reciever? Most digital receivers I'm familiar with don't pre-assign the digital audio inputs to AV sources, because they don't know what combination of optical and coaxial digital outputs your particular components might have. Instead they let you assign, say Digital 2 (Optical) to Video 1, and Digital 4 (coax) to Video 2, etc. Regards, Joe
#5 of 6 OFFLINE   Buckethead78
Buckethead78
  • 74 posts
Posted September 21 2008 - 05:54 AM
Joe -- Yep, inputs are assigned. The receiver does recognize the signal as the receiver has "dolby digital" onscreen. If it was not getting a signal, it would be in "Logic 7" mode.
I just can't figure out why there's no sound from the speakers Posted Image
#6 of 6 OFFLINE   Buckethead78
Buckethead78
  • 74 posts
Posted September 22 2008 - 09:44 AM
Could it be the cable then? Even if I see some red light from the end?
