Jump to content
How do I extend / bridge my wired network?
  • Please log in to reply
12 replies to this topic
#1 of 13 OFFLINE   DaveF
DaveF
  • 15,525 posts
  • Real Name:David Fischer
  • LocationOne Loudoun, Ashburn, VA
Posted August 16 2008 - 03:55 PM
My Airport Extreme Base Station's 3 ethernet ports are full, and I want to connect a fourth wired device to it. How can I do this? The third ethernet output runs to the living room, connecting the Tivo to the LAN. I plan to add a videogame system which also needs to be networked. Can I connect that ethernet cable into the WAN input of a wired hub or router and then plug the Tivo and videogame into the outputs of the hub/router? I don't know the language to use to effectively google this solution. Everything is about extending a wireless network, but I want to be wired. Thanks for any help.
#2 of 13 OFFLINE   Joe Casey
Joe Casey
  • 226 posts
Posted August 16 2008 - 11:11 PM
An inexpensive ethernet hub or switch will do the job. Being that you're using an Extreme, there's no need to spend the extra money on a gigabit hub (1000Mbps), as it only supports transfer rates up to 100Mbps.
An example of what you could use:
Dynex® - 5-Port 10/100 Ethernet Switch - DX-ESW5
Q
#3 of 13 OFFLINE   JohnRice
JohnRice
    Lead Actor
  • 8,631 posts
  • Real Name:John
Posted August 17 2008 - 04:55 AM
I've been curious about this as well, as I'm expanding my wired/wireless network. The one thing I'm pretty sure of is that a router will not work. The thing I wondered is if a regular switch will.
The Hybrid System
The Music Part: Emotiva XSP-1, Thiel CS 3.6, Emotiva XPA-2, Marantz SA8004, Emotiva ERC-3, SVS PB-12 Plus 2
The Surround Part: Sherbourn PT-7030, Thiel SCS3, Emotiva XPA-5, Polk & Emotiva Surrounds.
#4 of 13 OFFLINE   DaveF
DaveF
  • 15,525 posts
Posted August 17 2008 - 06:31 AM
Thanks Posted Image
#5 of 13 OFFLINE   DaveF
DaveF
  • 15,525 posts
Posted August 17 2008 - 11:49 AM
I should ask: is there any "magic sauce" after that? Special settings for the AEBS, or simply plug and play?
#6 of 13 OFFLINE   JohnRice
JohnRice
    Lead Actor
  • 8,631 posts
  • Real Name:John
Posted August 17 2008 - 12:35 PM
Switches don't have settings at all. You just have to use the #1 port for "upstream", aka, going toward the internet source.
The Hybrid System
#7 of 13 OFFLINE   nolesrule
nolesrule
    Producer
  • 3,084 posts
  • Real Name:Joe Kauffman
  • LocationClearwater, FL
Posted August 17 2008 - 04:33 PM
Make sure you get a switch though, not just a hub. Hubs are prone to data collisions while switches have software to internally manage data paths on the downstream network. Usually, you can attach up to 254 devices to a single router (based on the typical default subnet mask), meaning you can daisy chain multiple switches as needed.
#8 of 13 OFFLINE   JohnRice
JohnRice
    Lead Actor
  • 8,631 posts
  • Real Name:John
Posted August 18 2008 - 02:40 AM
I didn't think hubs were even made anymore. The term has just stuck.
The Hybrid System
#9 of 13 OFFLINE   DaveF
DaveF
  • 15,525 posts
Posted August 18 2008 - 04:47 AM
There's switch on sale this week, similar to what Joe suggested, for $15 that I think will do the trick.
I think I'm getting an XBox 360, which I need to connect, with my Tivo to a single ethernet output in the living room. I plan to get the switch, plug the ethernet cable to its input, and the Tivo & 360 to the outputs of the switch. And hopefully it will just work. Posted Image
#10 of 13 OFFLINE   nolesrule
nolesrule
    Producer
  • 3,084 posts
Posted August 18 2008 - 05:46 AM
I run into a hub for sale every so often at CompUSA, so you just have to pay attention. Probably old stock. If it actually says hub on the package you need to avoid it.
#11 of 13 OFFLINE   JohnRice
JohnRice
    Lead Actor
  • 8,631 posts
  • Real Name:John
Posted August 18 2008 - 02:42 PM
Maybe that's why CompUSA went out of business.
The Hybrid System
#12 of 13 OFFLINE   nolesrule
nolesrule
    Producer
  • 3,084 posts
Posted August 18 2008 - 05:09 PM
No. They went out of business because they tried competing with Best Buy and Circuit City rather than sticking to what they were good at, which was a dedicated computer/parts/software shop. I was so happy when TigerDirect re-opened my CompUSA in its old form. Now I can find what I need for clients that are in a hurry without having to wait for shipping.
#13 of 13 OFFLINE   DaveF
DaveF
  • 15,525 posts
Posted September 05 2008 - 03:22 PM
A followup: I'd given a friend my old Linksys router / switch. He gave it back; he wasn't using it. I plugged in my LAN cable to the uplink port, and plugged the Tivo into port 1 and it worked normally. I then added my new Xbox 360 to port 2 and it connected onilne without issue.
So pleased this network configuration was free and trivial. Posted Image
