Jump to content
Difference between A speakers and B Speakers
5 replies to this topic
#1 of 6 OFFLINE   bob733
bob733
  • 2 posts
Posted July 26 2008 - 09:12 AM
Is there any difference between the A and B speakers? The A speakers have large red and white ports while the B speakers have small ports.
I know they are used (for example) if you have speakers in another room but what about any difference between the volume or output levels etc?
The reason I ask is because I had a problem hooking my cables up to the A speakers so I used the B speakers (which ports were easier to attach the cable).
Thanks in advance,
Bob
#2 of 6 OFFLINE   Carl Gaff
Carl Gaff
  • 280 posts
Posted July 26 2008 - 10:51 AM
Normally both the A & B speakers hook-ups offer the same power/output to the speakers but I would check your receiver's manual to make sure
#3 of 6 OFFLINE   JohnRice
JohnRice
    Lead Actor
  • 8,580 posts
  • Real Name:John
Posted July 26 2008 - 03:59 PM
There is far too much variance between how the A and B works on every receiver ever made in the history of audio to give any constructive answer to the question with the info provided.
The Hybrid System
The Music Part: Emotiva XSP-1, Thiel CS 3.6, Emotiva XPA-2, Marantz SA8004, Emotiva ERC-3, SVS PB-12 Plus 2
The Surround Part: Sherbourn PT-7030, Thiel SCS3, Emotiva XPA-5, Polk & Emotiva Surrounds.
#4 of 6 OFFLINE   Carl Gaff
Carl Gaff
  • 280 posts
Posted July 26 2008 - 04:25 PM
That's why I advised him to check his manual..............
#5 of 6 OFFLINE   Cloud
Cloud
  • 44 posts
Posted July 27 2008 - 01:54 AM
Quote:
I'd have to agree here. I can use my B hookups for bi-amping, for a zone 2, or for ambiance speakers all depending on how I setup the receiver. My last receiver just output the exact same signal and power to both A and B. All depends on what receiver you have and how it's set up.
#6 of 6 OFFLINE   bob733
bob733
  • 2 posts
Posted July 27 2008 - 03:56 AM
I have the Sony STR-DG720 Multi Channel AV Receiver and I have been checking the manual for any difference between the A and B Speakers.
Haven't seen anything yet so I am assuming there is no real difference.
Bob
