Jump to content
Sound clips from DVD
  • Please log in to reply
7 replies to this topic
#1 of 8 OFFLINE   Sam Posten
Sam Posten
  • 18,961 posts
  • Real Name:Sam Posten
  • LocationAberdeen, MD & Navesink, NJ
Posted April 11 2008 - 06:44 AM
First, no, I'm not trying to pirate something =p All I wanna do is grab a 15 second sound clip and save it to an MP3 and also get a single full size screenshot off a DVD. What's the fastest, easiest and cleanest way to do this on OSX, preferably for free?
I lost my signature and all I got was this Nutter t-shirt
HTF Rules
Classified Sales Rules
UV Sales New Clarifications
#2 of 8 OFFLINE   JohnRice
JohnRice
    Lead Actor
  • 8,637 posts
  • Real Name:John
Posted April 12 2008 - 11:42 PM
I have grabbed sound clips by basically routing the audio output back to the input and capturing with CDSpindoctor, which is part of Toast. I believe there is a shareware app which can do it easier, but I forget the name, and you have to pay to do it.
Screen captures are a bit stickier. I think you can play the DVD with VLC, pause, and do a regular screen capture, but you get a somewhat low quality image. This does not work with DVDPlayer. There is another, higher quality method I know of, because I like getting movie stills, but it involves software which can't be discussed on HTF, because it is capable of other bad things in addition to the screen captures.
The Hybrid System
The Music Part: Emotiva XSP-1, Thiel CS 3.6, Emotiva XPA-2, Marantz SA8004, Emotiva ERC-3, SVS PB-12 Plus 2
The Surround Part: Sherbourn PT-7030, Thiel SCS3, Emotiva XPA-5, Polk & Emotiva Surrounds.
#3 of 8 OFFLINE   Sam Posten
Sam Posten
  • 18,961 posts
Posted April 13 2008 - 05:02 AM
OK John, Thanks for the info! I guess I'm gonna have to do this on the PC cause it seems a LOT simpler to do there with free software...
HTF Rules
#4 of 8 OFFLINE   David Rubenstein
David Rubenstein
  • 83 posts
Posted April 13 2008 - 12:01 PM
Cinematize is probably the best (without using final cut). It's pretty inexpensive and easy to use.
David Rubenstein
My Theater: http://www.hometheat...ment/28664.html
#5 of 8 OFFLINE   Jon Martin
Jon Martin
  • 2,219 posts
Posted April 14 2008 - 03:11 AM
VLC does work for screengrabs on the Mac, although it is a very clunky program. That is the one area where PC is much better. The free program that came with my PC had a great screengrab program as part of the regular DVD player. I do a lot of DVD screengrabs for my site, but have had to cut back because of it. I'm not sure how to get audio files.
#6 of 8 OFFLINE   Sam Posten
Sam Posten
  • 18,961 posts
Posted April 14 2008 - 05:22 AM
I've been thinking of getting Power DVD Ultra for the PC anyway, maybe that's the way to go. Still looking into Cinematize tho!
HTF Rules
#7 of 8 OFFLINE   Shane D
Shane D
  • 651 posts
Posted April 14 2008 - 05:30 AM
i think there is as program called audio hi-jack. it should let you record music from any app. until you pay the shareware you only get like 30 seconds or something. but for 15 seconds should be ok
Rogue Amoeba - Pick Audio Hijack Pro or Radioshift
#8 of 8 OFFLINE   Sam Posten
Sam Posten
  • 18,961 posts
Posted April 14 2008 - 08:07 AM
That looks perfect thanks!
HTF Rules
