Jump to content
Plz help finding a projector.
  • Please log in to reply
4 replies to this topic
#1 of 5 OFFLINE   t1mberwolf
t1mberwolf
  • 14 posts
Posted April 08 2008 - 12:36 PM
Can anyone give me a suggestion on some projectors. I'm in the process on building a home theater. My room is 23 feet long by 12 feet wide. I was thinking of having a 8 foot wide screen. Does this sound right for this room. I need to pick a projector i believe so i can run a HDMI cable before i close in the walls. Which brings up my next question where to get a 32 foot HDMI cable? Any suggestions on type or brand of cable? Thanks for any input TImber
#2 of 5 OFFLINE   Jim Mcc
Jim Mcc
    Producer
  • 3,710 posts
  • Real Name:Jim
  • LocationOconomowoc, WI.
Posted April 08 2008 - 01:53 PM
Monoprice.com for any cables. The screen size depends on your seating distance, not the room size. You need to give much more info before we can recommend any projectors. The first thing you need to do is decide on LCD or DLP. What is your budget for projector? 720p or 1080p? What is your ceiling height? Will you ceiling mount it?
#3 of 5 OFFLINE   Ennsio
Ennsio
  • 264 posts
Posted April 09 2008 - 04:02 AM
Projectorcentral.com is the best place to go to read up on the different projectors available, and they have professional reviews and a guide for viewing distance vs. screen size for each projector available. That's where you should start your research.
#4 of 5 OFFLINE   Jim Mcc
Jim Mcc
    Producer
  • 3,710 posts
  • Real Name:Jim
Posted April 09 2008 - 09:18 AM
And Projectorreviews.com. Their reviews are much more thorough and detailed.
#5 of 5 OFFLINE   Gregg Loewen
Gregg Loewen
    Video Standards Instructor, THX Ltd.
  • 6,362 posts
  • Real Name:Gregg Loewen
  • LocationNew England
Posted April 13 2008 - 12:55 PM
you need to consider which PJ you want, throw distance, and screen size, before you consider cable length.
The Sonodome - circa 2001
The Newest Sonotube - circa 2001
Gregg's DVDs updated...sometimes
Lion Audio Video Consultants usually current
