Jump to content
Removable Power Cord - Need Help!
1 reply to this topic
#1 of 2 OFFLINE   Lin Park
Lin Park
  • 289 posts
Posted April 07 2008 - 02:28 PM
Bought some PS Audio cables to replace the standard detachable power cables that came with my speakers. The speaker has a standard IEC 60320 C14 female connector and the new PS Audio cable has a standard C13 male connector. The problem is that the new cable is so large near the end of the cable that it can't get past the cooling fins on the amplifier to plug into the connection. Does anyone know of a simple 1" to 2" extender (would love one with a 90 degree turn as well if it exists) for a C14 connection or know a better solution to solve this problem? I really don't want to do any damage to the speaker or cable to make the connection.
Lin
#2 of 2 OFFLINE   Lin Park
Lin Park
  • 289 posts
Posted April 10 2008 - 06:33 AM
Found exactly what I needed right here:
Plug Adapter IEC 60320 C14 Plug to IEC 60320 C13 Connector 10a/250v Block Adapter - Our Item #: 1421, Category: AC Adapters : StayOnline.com
Works perfectly in case anyone else needs this.
Lin
