Jump to content
HT subwoofer rattle
  • Please log in to reply
11 replies to this topic
#1 of 12 OFFLINE   gduncan27
gduncan27
  • 5 posts
Posted April 01 2008 - 01:54 AM
I just purchased a Philips DVD Home Theater System HTS3544/37, I've only had it for one day and the subwoofer is rattling. I ran a test on it playing a sound that runs from 100hz down to 15hz and the closer it got to 15hz the more it rattled. I know if it is the sub that is rattling and not something in the wall or around the sub. It is s a passive 8" high efficiency 8 ohnm sub. Any suggestions on what might be the problem and how I might go about fixing it? I tried to post a link to the HT System via the Philips website but this is my first post. If you google the model you should be able to find it.
#2 of 12 OFFLINE   Robert_J
Robert_J
    Lead Actor
  • 8,204 posts
  • Real Name:Robert
  • LocationMississippi
Posted April 01 2008 - 02:34 AM
Since it is a passive sub, it can only be the 8" driver, the cabinet or the wire inside the cabinet causing the vibration. You need to eliminate them one by one. For the driver, remove it from the cabinet and play your test tone through it at a low volume. For the wire, secure it inside the cabinet with glue or duct (duck) tape. You can also wrap it in foam. For the cabinet, tap on each side and listen for rattles. Is it small enough to pick up and shake? Shake it. If none of these are your issue, it may be the driver/cabinet connection. Use closed cell foam weatherstripping to seal the driver to the sub cabinet. This is a long shot but how loud were you playing the test tone? A 15hz tone at high volume can be brutal on a HTiB sub. You may be pushing your sub to its mechanical limits. If you do that too much, you will destroy the driver and may take the sub amp with it. -Robert
#3 of 12 OFFLINE   gduncan27
gduncan27
  • 5 posts
Posted April 01 2008 - 02:54 AM
The test tone was played at pretty low volume. The volume goes up to about 30 and I had it no higher than 12-15. This is a newb question but what is the 8'' driver?
#4 of 12 OFFLINE   gduncan27
gduncan27
  • 5 posts
Posted April 01 2008 - 03:03 AM
I'm having trouble opening the casing up. I was only able to find two screws and I don't really want to force/pry it open. When I shake it nothing rattles so I'm assuming its not the wire.
#5 of 12 OFFLINE   JohnRice
JohnRice
    Lead Actor
  • 8,589 posts
  • Real Name:John
Posted April 01 2008 - 03:43 AM
There is probably not much if anything you can do. I am guessing it is a plastic housing, and it is most likely just going to rattle. Also, those types of housings tend to lock together with plastic tabs in the inside to make them easy to assemble, but tricky to open.
The Hybrid System
The Music Part: Emotiva XSP-1, Thiel CS 3.6, Emotiva XPA-2, Marantz SA8004, Emotiva ERC-3, SVS PB-12 Plus 2
The Surround Part: Sherbourn PT-7030, Thiel SCS3, Emotiva XPA-5, Polk & Emotiva Surrounds.
#6 of 12 OFFLINE   gduncan27
gduncan27
  • 5 posts
Posted April 01 2008 - 04:01 AM
I've been just kind of playing around with it when I squeeze the two sides together the rattling stops so I'm guessing it's just the casing. I just need to figure out how to tighten the casing and get it to stay
#7 of 12 OFFLINE   Robert_J
Robert_J
    Lead Actor
  • 8,204 posts
  • Real Name:Robert
Posted April 01 2008 - 05:43 AM
Here is a picture of a raw driver - link. The sub is the entire system consisting of the driver and enclosure. In most cases, the sub also includes a built in amp. A driver can be anything from a 10mm tweeter to a 18" sub that weighs 80 pounds.
-Robert
#8 of 12 OFFLINE   JohnRice
JohnRice
    Lead Actor
  • 8,589 posts
  • Real Name:John
Posted April 01 2008 - 08:14 AM
A couple very large rubber bands may be all you need.
The Hybrid System
#9 of 12 OFFLINE   gduncan27
gduncan27
  • 5 posts
Posted April 01 2008 - 04:14 PM
Tried the rubber bands but didn't do to much, weren't strong enough.
#10 of 12 OFFLINE   chuckg
chuckg
  • 917 posts
Posted April 02 2008 - 07:54 AM
Crazy glue? A well-positioned sheet metal screw? Lay the sub on its side and put a concrete block on top? A really big C-clamp and a piece of carpet?
whatever works... Posted Image
--ignore the man behind the curtain
#11 of 12 OFFLINE   Vin_G
Vin_G
  • 111 posts
Posted April 08 2008 - 08:46 AM
Can you open the cabinet by chance? If so you may be able to add a small, diagonal brace or two to reinforce.
#12 of 12 OFFLINE   Barry_B_B
Barry_B_B
  • 453 posts
Posted April 09 2008 - 01:14 AM
Maybe the expandable foam they use to deaden car interiors or fill holes in concrete? It won't be very pretty but you could sand it down and paint over it.
