Jump to content
No audio on some channels with Panasonic Plasma... ?
  • Please log in to reply
3 replies to this topic
#1 of 4 OFFLINE   Adam Bluhm
Adam Bluhm
  • 611 posts
Posted March 29 2008 - 11:30 AM
My parents have a Panasonic TH-42PD60U plasma television. The set is connected directly to cable via coax (local cable co.). They also have a DVR connected, but I believe that's connected via component cables and stereo audio cables. Just recently it began giving trouble. Some channels have no audio but put out a normal picture. Other televisions in the house put out audio to every channel, so I have to assume it's not the cable's problem. I turned on the DVR and watched tv through that ('component 1' video setting) and every channel has audio when watching live through the DVR. I'm stumped. I unplugged the tv for a minute and rechecked all the connections. I even went through the channel programming guide to re-program all the channels, but the problem remains. Any ideas?
Mr. JBL has made my first home theater possible.
#2 of 4 OFFLINE   Adam Bluhm
Adam Bluhm
  • 611 posts
Posted April 04 2008 - 05:29 AM
Well, nevermind. Posted Image It appears that all channels now have audio. I have no idea what the problem is/was, but I guess I cannot fix what's not broke.
#3 of 4 OFFLINE   plasmasown
plasmasown
  • 3 posts
Posted April 04 2008 - 09:12 PM
Hi, it is because some channels broadcast 2 different languange options. Hit the SAP button on the remote to cycle through them as some of them are silent. Not all channels have this but it is likely that the ones that have no sound are set on the wrong one. I did have experience with this problem and it solved it.
#4 of 4 OFFLINE   Adam Bluhm
Adam Bluhm
  • 611 posts
Posted April 07 2008 - 05:58 AM
Thanks for the reply, plasmas. I played with the SAP button and you are exactly correct. It's good to know. Posted Image
Such a simple resolution to a frustrating problem!
