Jump to content
Not rated for "In Wall"
  • Please log in to reply
17 replies to this topic
#1 of 18 OFFLINE   chris.big.money
chris.big.money
  • 106 posts
Posted March 23 2008 - 04:00 AM
So in my quest for extending HTiB cables, i only found 22 gauge wire that was not rated for "in wall" installation. is this a big deal? the wall and ceiling that i'm running them through don't have insulation, in case this affects the wire in some way.
#2 of 18 OFFLINE   JohnRice
JohnRice
    Lead Actor
  • 8,641 posts
  • Real Name:John
Posted March 23 2008 - 04:44 AM
You should be able to find cable both rated and not rated for in-wall use in pretty much any gauge. Are you saying you are intent on getting cable which is NOT in-wall rated? Even though fire is not much of a risk, you should still get in-wall rated wire, since its insulation is designed to endure the environment inside the walls. Regular insulation will dry and crack eventually, which is the last thing you want. Don't use 22 ga though. Use a minimum 14. If you aren't "pulling" the wire, you can even use Romex.
The Hybrid System
The Music Part: Emotiva XSP-1, Thiel CS 3.6, Emotiva XPA-2, Marantz SA8004, Emotiva ERC-3, SVS PB-12 Plus 2
The Surround Part: Sherbourn PT-7030, Thiel SCS3, Emotiva XPA-5, Polk & Emotiva Surrounds.
#3 of 18 OFFLINE   Ken Seeber
Ken Seeber
  • 789 posts
Posted March 23 2008 - 10:20 AM
You'll find everything you could hope for here: Speaker Wire
#4 of 18 OFFLINE   chris.big.money
chris.big.money
  • 106 posts
Posted March 24 2008 - 01:21 AM
well i know that there is in wall rated wire for almost any wire....but at radioshack all i could find is not in wall rated 22 guage. and i can't use any less than that because the wires that i am extending from a HTiB are just about that gauge. Do you think it will make a huge difference? And how long will it take before it starts cracking from being in the wall?
#5 of 18 OFFLINE   Al.Anderson
Al.Anderson
  • 2,383 posts
  • Real Name:Al
Posted March 24 2008 - 01:50 AM
I don't think not having in-wall wire will affect you much. Since I'm not an electrician or a building inspector that should be interpreted to mean - I've done it (with 14 guage) with no apparent ill effect; and that was going through an exterior wall. I'd be more concerned with the use of the 22 guage. How long is the run you're winding up with?
#6 of 18 OFFLINE   Paul Padilla
Paul Padilla
  • 767 posts
Posted March 24 2008 - 02:53 AM
"In-wall" rating has much less to do with insulation cracking and being a hazard than it has to do with the insulation material itself contributing to a fire in the event one begins from another source. Wire not rated for in-wall can act like a fuse inside the wall during a house fire and hasten the spread.
And I agree...22g is way too small in any event. 14g minimum and depending on the length, 12g would be even better.
I'm a ****ing idiot 'cause I can't make a lamp?
No, you're a genius 'cause you can't make a lamp.
What do you know about trigonometry?
I could care less about trigonometry.
Did you know without trigonometry there would be no engineering? Without lamps there'd be no light.
#7 of 18 OFFLINE   chris.big.money
chris.big.money
  • 106 posts
Posted March 24 2008 - 06:25 AM
really? the wire that came with the HTiB (connected to speakers) was at least 22 gauge, if not smaller. that wire was expected to run through walls etc. right? and the maximum i could use would be 18 gauge, because the butt splices (red ones) are only rated for 18-22 and since the HTiB wire is so small, i figured that'd be the best size. also, before i moved the A/V components to the back of the room, i had the wires running through ceiling and walls and it didn't seem to affect anything. how long will it take for the insulation to become so damaged that it requires removal and substitution with new wire?
#8 of 18 OFFLINE   chris.big.money
chris.big.money
  • 106 posts
Posted March 24 2008 - 06:27 AM
it's not very long...i'm thinking (rough estimation) the longest wire is about 35 ft. and that's going through a drop ceiling and the walls. does it affect it more if it's going through the ceiling or the walls?
#9 of 18 OFFLINE   Jeff Gatie
Jeff Gatie
    Lead Actor
  • 6,531 posts
Posted March 24 2008 - 07:22 AM
The HTiB wire is 22 gauge to save cost. Most people recommend 14 gauge for runs up to 50 ft and 12 gauge for over 50 ft.
#10 of 18 OFFLINE   Paul Padilla
Paul Padilla
  • 767 posts
Posted March 24 2008 - 07:27 AM
Chris...take another look at my last post. Degradation of the insulation isn't the big concern.
#11 of 18 OFFLINE   chuckg
chuckg
  • 917 posts
Posted March 24 2008 - 08:02 AM
The rating for in-wall use is a fire prevention issue, and has nothing to do with the capability of the wire for its intended use. Speaker wire should be as thick as practical. The lower the number, the bigger the wire. I would (almost) never use anything less than 16 gauge, and almost exclusively use 12 gauge. You can solder the skinny speaker wire onto something larger for the long runs. For a home theater system, 35 feet is getting into the "long run" category. There is almost NO checking what you do inside your own home. You can use wire which is not in-wall rated, and it is likely that no-one will ever know. Your insurance company might use it as an excuse to deny a claim if there is a fire, though.
--ignore the man behind the curtain
#12 of 18 OFFLINE   Brent_S
Brent_S
  • 472 posts
Posted March 24 2008 - 12:16 PM
A good home inspector should also notice it if you ever sell the house. At which point you'll either be required to remove it or replace with appropriate in-wall rated wire. Such a discovery would probably encourage said inspector to look more closely at everything else while he was it. -Brent
#13 of 18 OFFLINE   JohnRice
JohnRice
    Lead Actor
  • 8,641 posts
  • Real Name:John
Posted March 24 2008 - 01:38 PM
It typically takes several years for the insulation on regular wire to break down. In-wall wire should last almost indefinitely. Don't look at Radio Shack. Go to a home center like Lowe's or Home Depot and get bulk wire.
The Hybrid System
#14 of 18 OFFLINE   Ken Seeber
Ken Seeber
  • 789 posts
Posted March 24 2008 - 02:27 PM
Again, I'd recommend buying from Monoprice. They ship fast, and it'll be hard to beat $30 for 100 feet of 12-gauge, CL-2-rated in-wall speaker wire.
#15 of 18 OFFLINE   gene c
gene c
    Producer
  • 5,807 posts
  • Real Name:Gene
  • LocationBay area, Ca
Posted March 24 2008 - 02:31 PM
I recently bought three rolls of these from monoprice. 12 gauge, CL2 and $15.95 for a 50 foot roll (cost me $12.85 two weeks ago) plus a little shipping. It looks a bit thin for 12g but it should be fine.
"Everyday room": Panasonic 58" Plasma, Dish HD DVR, Pioneer Elite vsx-23, BDP-23 BR, dv58avi universal dvd player, Paradigm Studio 20 V1, CC-450, Dayton HSU-10 subwoofer.
"Movie/Music room": Toshiba 65" DLP, Dish HD receiver, Marantz 7005, CC-4003, BD-7006, Polk LSI25's-LSi7's-LSiC, 2 original Dayton 10" "Mighty-Mites" subwoofers. (subject to change without notice).
Also have  MB Quart Vera VS05 +.....too much to list. Help me.
#16 of 18 OFFLINE   chris.big.money
chris.big.money
  • 106 posts
Posted March 25 2008 - 12:19 PM
okay so just to top it off....i already ran the wire using butt splices. it was 22 gauge. i probably shouldn't, but i had already bought and opened it and didn't feel like going through the process of finding receipts etc. so will i ever have a difference in sound quality or anything? if it's over (x) amount of years then i'll be able to buy a couple hundred feet of 12 gauge or something when i need to because of the cash involved. So just to clear it up in case something happens with my wire; if i were to eventually get some 12-18(?) gauge wire to replace the now-named "temporary" wire, how would i connect it to the wimpy HTiB wire? Is there anything short of soldering it? Thanks for all the help everyone. Even though i ran the other wires, i now know what to get in case something happens and am closer to not being labeled "a beginner"
#17 of 18 OFFLINE   Robert_J
Robert_J
    Lead Actor
  • 8,249 posts
  • Real Name:Robert
  • LocationMississippi
Posted March 26 2008 - 12:48 AM
Soldering the wires is the best connection you can have. Is there any reason you didn't go that route in the first place? -Robert
#18 of 18 OFFLINE   chris.big.money
chris.big.money
  • 106 posts
Posted March 26 2008 - 11:41 AM
well i was trying to go for the easiest, but still reliable connection. and i'd heard that butt splices were very reliable. so i used those instead of soldering simply because i did not feel the need to solder all the cables. so if these cables do ever wear out i can just get some 14 gauge wire and take out the butt splices and simply solder the wires together? what if they are different materials (i.e. the wire in the HTiB is silver material and not copper like other wire i've seen)?
