Jump to content
wireless audio / pc to receiver
4 replies to this topic
#1 of 5 OFFLINE   bbxrider
bbxrider
  • 2 posts
Posted January 15 2008 - 03:46 PM
ready to go wireless from my pc to my receiver
i've checked ads and specs for x.x gigahertz devices like lola x-10 and logitech VS wireless lan from linksys wireless music bridge.
i alrady have a wireless router so thats not an issue.
i v'e read someplace that digital signals are better than analog for the
wireless. i'm not sure which are which with these devices.
any opinions or experience shared with this would be helpful
thanks bob
#2 of 5 OFFLINE   SethH
SethH
  • 2,867 posts
Posted January 15 2008 - 09:39 PM
Have you considered something that will do video too? Here are two examples:
D-Link DSM-750 Wireless N HD Media Center Extender
Apple - Apple TV
If you don't care about video, then just those products you mentioned should be fine. Music will probably do fine on the 802.11b wireless standard, although you may here a few hiccups depending on how far away from the router you are. You would probably be better off going to 802.11g or 802.11-PreN if you don't have one of those already.
wireless.
All wireless signals being generated by computers (e.g. anything coming through your wireless router) are digital.
#3 of 5 OFFLINE   Jeff_CusBlues
Jeff_CusBlues
  • 605 posts
Posted January 16 2008 - 05:38 AM
How about the Squeezebox? I've heard great things about this device. I don't own one, but am considering one. I believe it requires at least 802.11g.
Edit: I'm not sure, but I think the Squeezebox does not do video.
#4 of 5 OFFLINE   bbxrider
bbxrider
  • 2 posts
Posted January 16 2008 - 07:04 AM
just looked at squeezebox, evidently its a high quality player/transceiver, the 24bit burr-brown. and it can play internet radio with the pc off which has merits.
but for the price diff 300 vs 65 for the linksys, i will probably go with the linksys or similar. my pc is always on anyway. probably if i step up to this quality and price range, i would look for a combo audio and video
#5 of 5 OFFLINE   Jeff_CusBlues
Jeff_CusBlues
  • 605 posts
Posted January 16 2008 - 10:43 AM
Yeah. The Squeezebox is pretty pricey, but I've heard great things about it. It is supposed to be easy to set up, and will play most all file types including FLAC. I'd forgotten about internet radio.
