Jump to content
So the 360 HDMI cable will not pass 5.1 audio?
5 replies to this topic
#1 of 6 OFFLINE   Kevin M
Kevin M
    Producer
  • 5,172 posts
Posted January 06 2008 - 04:12 AM
I have the Halo edition 360 and I hoped that I could run both that and my Sony up-converting DVD player to my HDTV and just run one optical cable to my receiver cutting back on the forest of cables behind my system....no such luck it seems as neither of the HDMI cables seem to want to pass a 5.1 signal to my TV and therefore to my receiver.
Bogus. I mean was this not one of the selling points of HDMI, it's ability to reduce the amount of cables needed to pass high quality A/V signals to HT systems?
-Kevin M.
There's a human tendency to resent anyone who disagrees with our pleasures.  The less mature interpret that as a personal attack on themselves.
- Roger Ebert
#2 of 6 OFFLINE   craig_curtis
craig_curtis
  • 179 posts
  • Real Name:Craig
  • LocationGlen Ridge, NJ
Posted February 08 2008 - 08:33 AM
yea I 'm right there with you. I foung a CHEAP hdmi cable on amazon, but if it doesn't pass the audio, I'll have to buy the $50 xbox specific cable, since it has the special widget for optical audio out of their LAME proprietary connection system.
Signature? What signature?!
#3 of 6 OFFLINE   Zack Gibbs
Zack Gibbs
  • 1,687 posts
Posted February 08 2008 - 10:00 AM
HDMI does output 5.1, as far as I know it's the only way to output the new lossless formats of HD as optical/coax doesn't have the bandwidth. Your problem is the TV isn't going to divert the HDMI signal to your receiver, it will only output stereo. You can't use your TV as the hub, the A/V receiver is the hub, you connect all your components to that and it goes out to the TV.
"Because he's the hero that Gotham deserves, but not the one it needs right now... and so we'll hunt him... because he can take it... because he's not a hero... he's a silent guardian, a watchful protector... a DARK KNIGHT."
#4 of 6 OFFLINE   Jeremy Little
Jeremy Little
  • 772 posts
Posted February 08 2008 - 10:06 AM
Zack has it right. You need to pass the HDMI to you receiver, then out to the tv. The tv cannot pass on the hdmi audio in 5.1 and the optical port on your tv is just for the integrated ATSC tuner.
If it wasn't for my horse, I wouldn't have spent that year in college.
#5 of 6 OFFLINE   TonyTone
TonyTone
  • 728 posts
Posted February 11 2008 - 05:00 AM
Quote:
I thought optical/coax does have the bandwidth to pass the new(er) HD audio formats, but that it was the implementation that prevented them from doing so--i.e., specification only allowed for pass-through via HDMI only. Sorta like how component video is quite capable of passing 1080p but the powers that be proclaimed that such would not be allowed.
#6 of 6 OFFLINE   Kevin M
Kevin M
    Producer
  • 5,172 posts
Posted February 27 2008 - 11:06 AM
Well if there is a way to make the 360's HDMI cable pass 5.1 to my HDMI switching Receiver then I haven't found the necessary menu in the 360's control panel to make it do so....for that matter I can't make my Sony up-converting HDMI DVD player do so either....any advice?
-Kevin M.
- Roger Ebert
