Jump to content
Has anyone had heat issues with HD/BD players due to location?
  • Please log in to reply
3 replies to this topic
#1 of 4 OFFLINE   Viper
Viper
  • 371 posts
Posted December 10 2007 - 11:58 PM
Why do the manuals to everything these days say not to put it in a cabinet, not to stack anything on it, etc? When you have 6 or 8 devices (or more), where the hell are you supposed to put them all? I currently have my 2 DVD recorders, HD-A3, and 2 VCRs on 1 shelf. There's plenty of room on the sides, but the back is closed in. Should I be concerned about the amount of heat being given off by the player and lack of ventilation? I kept checking the player after watching a couple movies, and it didn't feel warm. The second disc I took out was pretty warm though. My Halo 3 disc came out of my 360 hot almost hot enough to burn me one time; I sold that so I can get one of the newer ones that run cooler (Falcon chipset). I think I'm going to assume this setup will work for now. Do BD playes/PS3 have any heat issues? I probably won't be able to get one til next summer, but I may as well think ahead. I actually thought about cutting the sides/back of my media cabinets and installing 120mm PC case fans to help with this sort of thing. My Onkyo receiver runs hot as hell.
#2 of 4 OFFLINE   robocop2001
robocop2001
  • 12 posts
Posted December 11 2007 - 12:25 AM
I have a PS3 and a Toshiba HD-XA2. No heat issues as of date. I have my components in a Techcraft Wing series WF45B just because I wanted to avoid any possible heating issues. Years ago I use to keep my older components in an enclosed cabinet, and I noticed they really generated a lot of heat. Have you though about installing some computer fans in your cabinet to cycle hot air out and cooler fresh air in? Maybe this would help and put your mind at ease.
#3 of 4 OFFLINE   Clinton McClure
Clinton McClure
    Casual Enthusiast
  • 2,875 posts
  • Real Name:Clint
  • LocationCentral Arkansas
Posted December 11 2007 - 07:02 AM
I've often thought about installing computer cooling fans in my rack to help dissipate heat. I know they are low voltage so how would one go about wiring them up and not burning them up?
#4 of 4 OFFLINE   robocop2001
robocop2001
  • 12 posts
Posted December 11 2007 - 07:11 AM
I believe a voltage regulator would be needed, but I'm no electrician. I'm just guessing.
