Jump to content
Sign up for a free account!
Electricians: Why do diswashers have wall switches?
16 replies to this topic
#1 of 17 Wayne A. Pflughaupt
Wayne A. Pflughaupt
    Producer
  • 5,910 posts
Posted December 09 2007 - 07:58 AM
Not sure how much attention this will get with all these "Babe" threads going, but...
Never have understood, why do they put up wall switches for dishwashers, which basically switches the electrical outlet they are plugged in to. What’s the point of this? In an emergency, like if it’s overflowing or something, you can just unlatch the door and shut the thing off. With installation, you unplug the power cable from the wall and make your connections. I can’t say in over 25 years that I’ve ever used the DW switch for anything.
The reason I’m asking is I want to install under-cabinet lighting in our kitchen and utilize the DW switch for the them. Disconnecting the DW power leads from the switch I could wire-nut them together, giving the DW outlet unswitched power, and the switch would be available for the lights.
Any good reason not to do this?
Wayne A. Pflughaupt
My Equipment List
“A nice mid-fi system,” according to an audiophile acquaintance.
My Tech / DIY Articles and Reviews
#2 of 17 Dennis Nicholls
Dennis Nicholls
    Lead Actor
  • 7,613 posts
  • Real Name:Dennis
  • LocationBoise, ID
Posted December 09 2007 - 08:03 AM
I have NEVER seen a dishwasher plugged into a switched outlet. Maybe it's a local code? Posted Image
Now a garbage disposal needs a switch for obvious reasons. Maybe they wired both outlets under the sink to switches so you could decided later which one to use for the garbage disposal.
Feline videophiles Condoleezza and Dukie.
#3 of 17 Dennis*G
Dennis*G
  • 524 posts
Posted December 09 2007 - 08:41 AM
The DW on a switch is a new code to our area. I had never seen or heard of it until we went house hunting and all houses in the past 5 years have this switch.
I can think of no purpose for it either.
#4 of 17 drobbins
drobbins
  • 1,870 posts
Posted December 09 2007 - 08:44 AM
My current and last house have the dishwasher switch. There is no outlet though. Just straight wired. I have wondered about the reasoning behind this also.
#5 of 17 Clinton McClure
Clinton McClure
  • 2,694 posts
  • Real Name:Clint
  • LocationCentral Arkansas
Posted December 09 2007 - 09:17 AM
Maybe to prevent a small child who cannot reach the switch on the wall from putting a pet or sibling in the dishwasher and turning it on?
#6 of 17 DaveF
DaveF
    Executive Producer
  • 13,167 posts
  • Real Name:David Fischer
  • LocationOne Loudoun, Ashburn, VA
Posted December 09 2007 - 10:26 AM
Never seen it. How interesting.
Here were have a whole house fan that ventilates our "Energy Star"
home. It runs on a timer, programmed by the owner. My sister, in her big expensive new home in the South, is unaware of any such whole-house fan to ventilate the home properly.
This surprised me -- but apparently such things vary.
#7 of 17 Matt Stryker
Matt Stryker
  • 1,313 posts
Posted December 10 2007 - 09:30 AM
A friend had a whole house fan in his brick townhouse in ATL and I really liked it, but I was told that for sheetrock construction they weren't very useful due to the high humidity - A/C cools and dehumidifies the air, while the whole-house just circulates it....costs a heck of a lot less though. They do exist down south, you just have to find a non-wood house evidently.
And every house I've ever lived in has had the dishwasher on a wall switch - maybe the earlier ones went crazy or caught fire or something, so you needed a local disconnect. Any time you're mixing power and water plus moving parts theres always a chance of chaos I guess.
#8 of 17 Bryan X
Bryan X
    Producer
  • 3,469 posts
Posted December 10 2007 - 09:49 AM
Never seen a dishwasher wall switch. We built our house 7 years ago and don't have one.
#9 of 17 Henry Gale
Henry Gale
    Producer
  • 4,633 posts
Posted December 10 2007 - 10:33 AM
I've never had a dishwasher but I do have lots of wall switches.
"I was born to ramble, born to rove
Some men are searchin for the Holy Grail
But there ain't nothin sweeter
Than riden' the rails."
-Tom Waits-
#10 of 17 DaveF
DaveF
    Executive Producer
  • 13,167 posts
Posted December 10 2007 - 12:51 PM
Quote:
Here, the whole-house fan is solely for ventilation. We also have central A/C. I didn't run the house fan much the first two years and also kept rooms closed to reduce utility usage. Last summer, though, an Energy Star rep did a tour and inspection of my home (a survey they do, owner willing). He told me that not running the fan and keeping doors closed trapped moisture and in the long run put at risk for mold or mildew. "Seal it tight and ventilate it right" was the catchphrase, he said.
#11 of 17 Kevin Hewell
Kevin Hewell
  • 1,930 posts
Posted December 10 2007 - 04:58 PM
It's that all the time or can you just run the AC at times when it's the hottest? Where I live that amount to at least two months of the year.
#12 of 17 DaveF
DaveF
    Executive Producer
  • 13,167 posts
Posted December 10 2007 - 11:49 PM
Quote:
The house fan is simply an oversize ventilation fan in the master bath, with a programmable timer. The rule of thumb is to run it two hours per person per day. Mine is set to run from 11pm to 3 am every night. It's not for cooling or heating purposes; it's to bring in fresh air and remove excess humidity from the house.
The Central A/C, then, is normal A/C used in the summer. And of course, we've got a gas furnace for the winter.
#13 of 17 Bob Graz
Bob Graz
  • 798 posts
Posted December 11 2007 - 01:31 AM
I had never seen a wall switch for a dishwasher until I moved to Austin TX. We moved into a new house, went to use the dishwasher and nothing. I then remembered the builder telling me about the wall switch. Flipped it on and everything was great. It's code in TX, I really don't know why. It's not code anywhere else I've lived or currently live.
#14 of 17 Jeff_CusBlues
Jeff_CusBlues
  • 605 posts
Posted December 11 2007 - 04:36 AM
I have lived in northern Indiana my whole life (46 years) and have never seen a dishwasher switch. I also own 9 rental properties and a 139 unit seniors community built in the last 10 years and no switch. I'll have to ask my general contractor if he has heard of this and if so, why it is required in some places.
#15 of 17 Wayne A. Pflughaupt
Wayne A. Pflughaupt
    Producer
  • 5,910 posts
Posted December 11 2007 - 10:47 AM
Thanks for the feedback, folks. I’m tempted just to do away with it and use the switch for my lights. I have a buddy who’s in the remodeling business, I’ll see what he says before I do it. Posted Image
Wayne A. Pflughaupt
My Equipment List
#16 of 17 Dennis*G
Dennis*G
  • 524 posts
Posted December 11 2007 - 02:53 PM
ya know, unless you are selling the place or doing some home improvement that requires you to get an inspection, feel free to take it off the switch and live in peace!
#17 of 17 Chris Lockwood
Chris Lockwood
    Producer
  • 3,215 posts
Posted December 12 2007 - 05:32 AM
More money for certain people (the reason for many laws). I've never seen a wall switch for a dishwasher, either.
Back to After Hours Lounge
Forum Nav Content I Follow
