Patrick Sun
- Jun 30, 1999
Since buying a new prepro/receiver with HDMI audio processing capabilities is not in the budget for the near future (bought a new car recently), and my old Outlaw 950 only has 1 set of 5.1 analog audio inputs. Got the Toshiba XA2 and the Panasonic BDP-10A, both have at least 5.1 analog audio outputs (for lossless audio, and anything else they can decode). So I ended up using two of those 3-port A/V switchers (just simple mechanical switchers for RCA connector inputs), and fed the front L-R-C into one switcher from each source, and the rear L-R-Sub into the other switcher. The video side is handled with direct connection of HDMI to the TV set.
Originally I had the BDP-10A using the 5.1 analog audio input on the 950, and the optical audio output from the XA2, but I really wanted to hear TrueHD from HD DVD, and after comparing the downrezzed audio from the XA2 with the TrueHD, it was well worth the hassle and cost of the A/V switchers to get the sonic upgrade for both HDM sources now. Sure, it's a low-tech and clunky solution for now, but it'll have to do until I upgrade the prepro/receiver in the future.
