Jump to content
Can I unplug a hard-drive without Ejecting it first?
6 replies to this topic
#1 of 7 OFFLINE   DaveF
DaveF
    Executive Producer
  • 13,931 posts
  • Real Name:David Fischer
  • LocationOne Loudoun, Ashburn, VA
Posted October 25 2007 - 02:18 PM
Can I safely unplug an external, USB hard-drive from my Mac without first properly ejecting it? I'm examining whether I want to get an external USB hard drive for my MacBook Pro; but I like to pull the USB hub plug and power cord and take it from my desk. If I also have to first eject a hard-drive, then the nuisance factor starts to creep up too high.
(I do have an external on my AEBS. But apparently that won't work with Time Machine. Posted Image )
#2 of 7 OFFLINE   Michael_K_Sr
Michael_K_Sr
  • 1,345 posts
  • Real Name:MichaelK
  • LocationChicago 'burbs
Posted October 26 2007 - 12:05 AM
Eject it first. Over time you're going to corrupt data if you just pull the plug. Highlighting the drive and typing COMMAND+E only takes a second or two.
#3 of 7 OFFLINE   DaveF
DaveF
    Executive Producer
  • 13,931 posts
Posted October 26 2007 - 01:07 AM
Thanks Michael. I'll just not plug a USB drive into my MBP. I already forget to unplug my iPod at times, when I "undock". I don't need to put a backup drive at risk.
#4 of 7 OFFLINE   JeremyErwin
JeremyErwin
    Producer
  • 3,219 posts
Posted October 27 2007 - 05:32 AM
There's a little eject icon in the finder that provides an alternative to command-e, should you find that more convenient.
Doubtless, Apple has rearranged the finder for Leopard, though
Posted Image
#5 of 7 OFFLINE   DaveF
DaveF
    Executive Producer
  • 13,931 posts
Posted October 27 2007 - 08:42 AM
I've been looking for a simple Time Machine solution, since it no longer supports drives on the Airport Extreme. Plugging in a drive to the USB hub on my MacBook Pro would be inconvenient; every extra click and cable needed to untether from the desk makes it less usable. If I could unplug with impunity, it would be fine. But if the recommendation is to always Eject a drive before disconnecting -- well, that's just a bother.
I'm now looking at connecting a drive to my wife's desktop and using Time Machine with that drive, over the wireless network.
Thanks for the tips and comments.
#6 of 7 OFFLINE   Ken Chan
Ken Chan
    Producer
  • 3,302 posts
Posted October 29 2007 - 10:19 AM
Although it's not because it's some kind of cumulative problem. The issue is that the computer may not be done with the drive. Obviously, if some program is busy writing files to the drive, and you pull the plug, you can lose data. There's no physical way around this, how could there be?
The act of ejecting a USB/FireWire disk is (in part) you requesting the OS to tell you when it is safe to unplug it. It knows if there are pending writes to the disk. It knows if some application still has some files open, and it won't let you eject it.
Otherwise, it's Russian Roulette. If nothing is pending or open, you should be able to just pull the plug; things are designed to be tolerant in that way. However, the OS will rightly complain. Because you might think you know if it's safe -- "the light wasn't on" -- but you might be wrong. So you'll do it the one time that trashes something.
#7 of 7 OFFLINE   Al.Anderson
Al.Anderson
  • 2,193 posts
  • Real Name:Al
Posted October 30 2007 - 10:42 PM
Quote:
The act of ejecting a USB/FireWire disk is (in part) you requesting the OS to tell you when it is safe to unplug it ...
Not quite. The issue is what's called a "delayed write". What is going on is that the operating system buffers the physical I/O to optimize throughput - it's not efficient to write every little bit of data to the hard drive, so the data is stored up until the OS thinks it's a good time for a write. The application could have long ago completed it's write, but the data is in a buffer. Signaling an eject forces the OS to do that last write.
Forum Nav Content I Follow
