Jump to content
Second subwoofer cable length question.
6 replies to this topic
#1 of 7 OFFLINE   mitch
mitch
  • 89 posts
Posted October 24 2007 - 11:36 AM
Hi All, I'm thinking about adding a second sub to the back of my Home Theater room [about 30 feet from the front HDTV and receiver area]. My question is, how much sound degredation do you get if you use a decent cable [like a BetterCable or an Ultra from RiteAV]? I would probably have to order at least 50 feet in order to snake the cable up over the dropped ceiling and down through the paneling in the back. Would it help if I ordered more expensive cables considering the long run? If you have any other suggestions on cables, please let me know. Has anyone else had experience in setting up a second sub to their system? I currently have the SVS PB 12 Plus/2 [which I just got and love!], and I still have my Velodyne HGS 15 which I decided not to sell. The Velo would be the 2nd sub in the back [unless I reverse it and put the Velo in the front]. Thanks for the help as always, Mitch
#2 of 7 OFFLINE   JohnRice
JohnRice
    Lead Actor
  • 8,586 posts
  • Real Name:John
Posted October 24 2007 - 04:46 PM
Mitch, a lot of people seem to disagree with me, but I'm not a big fan of subs in the back of the room. Is there a place in the front, but not right next to the SVS where you can put the Velodyne? At least you don't have to get 50' of cable to try it out.
The Hybrid System
The Music Part: Emotiva XSP-1, Thiel CS 3.6, Emotiva XPA-2, Marantz SA8004, Emotiva ERC-3, SVS PB-12 Plus 2
The Surround Part: Sherbourn PT-7030, Thiel SCS3, Emotiva XPA-5, Polk & Emotiva Surrounds.
#3 of 7 OFFLINE   JohnRice
JohnRice
    Lead Actor
  • 8,586 posts
  • Real Name:John
Posted October 24 2007 - 06:06 PM
BTW Mitch, I'm wondering if you ever played anything with decent bass content at a good level, and sat on the sub... It's an experience, trust me.
The Hybrid System
#4 of 7 OFFLINE   Robert_J
Robert_J
    Lead Actor
  • 8,184 posts
  • Real Name:Robert
  • LocationMississippi
Posted October 24 2007 - 11:46 PM
Multiple subs in different locations can smooth the response IF you spend the time and have the tools to calibrate them accordingly. Otherwise you could end up with less bass than you started with. I'm a fan of going big in one location. That's why I use a pair of 15's with 2,000w of power in the front of the theater room. As for the cable, I like to use RG-59 or RG-6 with RCA connectors soldered on. It works just as well as retail cables and costs much less. -Robert
#5 of 7 OFFLINE   ChrisWiggles
ChrisWiggles
    Producer
  • 4,791 posts
Posted October 25 2007 - 10:39 AM
Not necessarily more expensive, but better. Analog sub cable runs are by FAR the least critical cables in the system. Your only real concern is just that it's well shielded. Any decent coax will work fine for that. If for whatever reason you want 100% overkill peace of mind, you can always go for canare/belden pro-grade cabling. But for a sub run, that's likely just a waste of money.
#6 of 7 OFFLINE   John Garcia
John Garcia
    Executive Producer
  • 11,559 posts
  • Real Name:John
  • LocationNorCal
Posted October 26 2007 - 05:46 AM
I personally don't like subs in the back of the room either. If you are going to have two, collocating will make your calibration issues far simpler. I second the RG-59/RG-6
HT: Emotiva UMC-200, Emotiva XPA-3, Carnegie Acoustics CSB-1s + CSC-1, GR Research A/V-1s, Epik Empire, Oppo BDP-105, PS4, PS3,URC R-50, APC-H10, Panamax 5100 Bluejeans Cable
System Two: Marantz PM7200, Pioneer FS52s, Panasonic BD79
(stolen) : Marantz SR-8300, GR Research A/V-2s, Sony SCD-222ES SACD, Panasonic BD-65, PS3 60G (250G)
Everybody is a genius, but if you judge a fish by its ability to climb a tree, it’ll spend its whole life believing that it is stupid.” – Albert Einstein
#7 of 7 OFFLINE   mitch
mitch
  • 89 posts
Posted October 26 2007 - 08:48 AM
Thanks for the great advice. I'm really happy with my new SVS PB 12 Plus/2 and it's probably plenty enough for my home theater [even though I'm a sub aholic!]. I'll probably just put my Velo on the market. Thanks, Mitch
