Jump to content
Help Choosing Sub!!
  • Please log in to reply
6 replies to this topic
#1 of 7 OFFLINE   ChrisKula
ChrisKula
  • 33 posts
Posted August 20 2007 - 01:04 PM
All, I am in the market for a new sub and have been looking at SVS as they come very highly recommended!! Basically my room is 12w x 14d x 8h and is open to the next room through a large doorway. I am looking for a smaller sub and was considering the SVS SB-12 Plus, however, I am concerned since the description states that it is a small sub and does not have as much output as its larger cousin (PB-12 Plus). I would like a smaller sub and do not listed to music or movies at earsplitting levels but want to be able to feel the bass during movies (90% of use for movies). Will the SB-12 be adequate for a room the size listed above...those who have or have heard this sub: your help is greatly appreciated!!
#2 of 7 OFFLINE   Shannon W
Shannon W
  • 195 posts
Posted August 20 2007 - 06:50 PM
My room is very close to the same size as the one you have mentioned and I upgraded to the PB12+2. Like the old say'n goes. There is no replacement for displacement! Shannon
50" Samsung Plasma AKA. Liquid Love
Sony STR-DA4ES "use as Pre/amp" AKA. The Old Man
Sony PlayStation3 AKA. Rick James "B*TCH"
Pioneer Elite DV-45A DVD Player AKA. Vito
Directv HR-20 (Black) Sat. Rec AKA. Charlie Murphy Sunfire Cinema Grand Sig. 7 AKA. The Juggernaut "On Fire"Monster Cable...
#3 of 7 OFFLINE   ChrisKula
ChrisKula
  • 33 posts
Posted August 21 2007 - 01:09 PM
Thanks for the reply! I realize that size does matter but I am wondering if the SB-12 is enough, I believe that the PB-12 will be louder, tighter, etc. but it is a trade off between size and output.... Any other opinions????
#4 of 7 OFFLINE   Shannon W
Shannon W
  • 195 posts
Posted August 21 2007 - 01:19 PM
Not to sound smug but what you need to do is find out whats your Budget then go from there. You budget should be the deciding factor on which one to get. But if it was me I say go for the PB12 instead of the SB-12. I had to wait over a year before I rat holed enough Coin to buy my beloved SVS. Now I just need to sell my velodyne sub that he SVS replaced so I can start looking for a new Preamp then the Sony receiver will be the next thing on the chopping block. I guess It will be on eBay this weekend. Shannon
#5 of 7 OFFLINE   ChrisKula
ChrisKula
  • 33 posts
Posted August 22 2007 - 09:57 AM
Thank you Shannon W! Budget is not so much an issue as size and quality. I want a sub that will sound great but not take up a good chunk of my room. The PB-12 will undoubtedly sound better all around but it is quite large at 25" x 18" footprint. I have been focusing on SVS but are there any other manufacturers I should be looking at?? Thanks!
#6 of 7 OFFLINE   ChrisKula
ChrisKula
  • 33 posts
Posted August 22 2007 - 09:56 AM
#7 of 7 OFFLINE   ChrisKula
ChrisKula
  • 33 posts
