D
DAN NEIR
I recently went high def w/ blu ray and am planning to upgrade my set. I currently own a 46in Mitsubishi that only supports 1080i w/ component inputs. I remember that when I bought the set(around 2000 I believe) I eventually had to figure out how to get into the service menus to fix the overscan problem the tv had. I also had a problem as red levels were too high when adjusting the color properly with Avia. I had to correct that problem w/ an attenuator from Radio Shack attached to the red component input.
I want a new set that supports 1080p, hopefully between 60 and 70in. Are the above problems still going to be something I'll have to deal w/ regarding the new set? Last time I was lucky to get info on the sevice menus and the color problem was fixed w/ the components, will it be correctable w/ an hdmi input?
