Jump to content
HDMI audio vs Fiber Optic audio
  • Please log in to reply
3 replies to this topic
#1 of 4 OFFLINE   TDP
TDP
  • 8 posts
Posted July 25 2007 - 07:36 AM
What is difference if any between running sound (along with video) thru an HDMI cable vs running sound thru a fiber optic cable. The reason why I ask. Well I just recently bought a Samsung dlp tv (3 hdmi inputs and 1 fiber optic out). I have both the cable dvr box and an upscaling dvd player connected to the tv via hdmi. but I have the sound from both devices connected directly to an Onkyo receiver via fiber optic cables. Am I missing anything sound wise? So I guess what I'm asking is "Is the sound from an hdmi cable setup better than a fiber optic setup?"
#2 of 4 OFFLINE   Paul Padilla
Paul Padilla
  • 767 posts
Posted July 25 2007 - 08:17 AM
With your setup, no. Both are digital. HDMI will only help if
    [*]You have a Blu-Ray or HD-DVD player[*]The aforementioned next gen player is being run into a receiver which also has HDMI and can decode the high def audio tracks.
Running the sound via HDMI (if your TV even supports it) will actually have the negative effect of it no longer being distributed to the speakers connected to your Onkyo. Fiiiiiiber is just fiiiiiiine. Posted Image
I'm a ****ing idiot 'cause I can't make a lamp?
No, you're a genius 'cause you can't make a lamp.
What do you know about trigonometry?
I could care less about trigonometry.
Did you know without trigonometry there would be no engineering? Without lamps there'd be no light.
#3 of 4 OFFLINE   TDP
TDP
  • 8 posts
Posted July 25 2007 - 09:04 AM
Ok. So the TV would need an hdmi output and the receiver would need an hdmi input? Right?
#4 of 4 OFFLINE   Paul Padilla
Paul Padilla
  • 767 posts
Posted July 25 2007 - 09:36 AM
Visa versa...but you're on the right track. The big thing, though, is the source. If you don't envision having Blu-Ray or HD-DVD, then you're not gaining anything. It will be the same old Dolby Digital or DTS you're getting now.
