16MM Fans: I need help... (1 Viewer)
Scooter
DFW Area Texas
Scooter
I just bought 2 16MM and 1 8MM from someone on Craig's List for $20.00. Both work but the Eiki needs belts. Finding the lamp for the B&H was a snap, and cheap to boot! But finding belts for the Eiki is a problem. Any links to dealers I can reach out to? It's the ST-OH model.
Thanks in advance
Mark Philp
Syracuse, New York
Mark
A friend of mine is the last "factory authorized" Eiki serviceman in Upstate New York and I'm pretty sure he can help you. Send me a private message and I'll give you his name address and number.
acinstallation715
