Two great cases I have found, each with different problems.
http://www.marware.com/PRODUCTS/iPho...eve-for-iPhone
Love this case! It is the pouch type, looks professional, and has an
extra long removable clip that will not slip off the belt.
The problem is that once you take the phone out, it is unprotected
so if you drop it there is nothing between the floor and your phone protecting it.
http://www.contourcase.com/isee/iseeiphone/
This is the acrylic cover I told you about. Not as professional looking, but
it does protect the phone while you have it in your hand.
Which would you choose? If you see any other cases you like please
share it with us.
share it with us.
