Jump to content
need help with running wires...
4 replies to this topic
#1 of 5 OFFLINE   KennethF
KennethF
  • 53 posts
Posted June 07 2007 - 02:36 AM
my den is in a corner of my one level house. house is on a slab. attic access. problem is... the room has a trey ceiling, and the tv wall with front channels is beneath the slope of the roof. obviously the space to drill holes in the attic to drop wires is VERY tight. any idea how i can drop some wires in this space without creating excess holes in the sheetrock?
thanks for the input!
#2 of 5 OFFLINE   Robert_J
Robert_J
    Lead Actor
  • 8,178 posts
  • Real Name:Robert
  • LocationMississippi
Posted June 07 2007 - 06:12 AM
Other options are behind baseboard or crown molding. There are also some plastic tracks that stick to the baseboards and you run the wires through them. White tracks on white trim at least blends. These are available at Home Depot, Lowes, etc. Or you can use a combination of methods. If a track won't go all the way around the room, use it to a good point on a wall where you can run inside the wall and through the attic.
Every house is different so you are the best to determine what will work.
-Robert
#3 of 5 OFFLINE   kisha12
kisha12
  • 12 posts
Posted June 10 2007 - 11:03 PM
' Oh Nice Post ''
#4 of 5 OFFLINE   Bud Huey
Bud Huey
  • 73 posts
Posted August 23 2007 - 02:09 PM
If you have carpeting in the room and you are trying to run speaker wires of reasonable guage a lot of the time you can tuck them under the baseboards with the carpet. Then I would cut a small hole in the sheetrock above the baseboard to fish them into the wall.
Good Luck,
Bud
#5 of 5 OFFLINE   Wayne A. Pflughaupt
Wayne A. Pflughaupt
    Producer
  • 5,930 posts
  • Real Name:Wayne
  • LocationKaty, TX
Posted August 25 2007 - 01:43 PM
You could drop the wires out of the attic right at the ceiling / wall juncture, then enter the wall right there. Cut out the little strip of sheetrock between the two holes, staple down the wire to the 2” x 4”, mud and paint.
Wayne A. Pflughaupt
My Equipment List
“A nice mid-fi system,” according to an audiophile acquaintance.
My Tech / DIY Articles and Reviews
