Jump to content
Sign up for a free account!
Using headphones on tv when there is no headphone jack
8 replies to this topic
#1 of 9 DanielBH
DanielBH
  • 27 posts
Posted June 05 2007 - 12:07 PM
I badly want to use headphones on my television, but I have no headphone jack in any piece of hardware related to the tv. I've read around, and it would seem that there is an adapter than can turn your audio outputs into a headphone jack; but I can not find anywhere that sells such an adapter. It could be that I'm just using the wrong words or looking in the wrong place, so maybe you guys can help me? I'm looking to use a cable for the headphones; I figure I have enough signals going penetrating my brain already. lol
#2 of 9 Bob McElfresh
Bob McElfresh
    Producer
  • 5,183 posts
Posted June 05 2007 - 02:27 PM
What type of audio outputs does your TV have?
If it has L/R RCA jacks, I believe Radio Shack has "Y" adapters that will join them to a 1/8" headphone jack (walkman style) or a 1/4" headphone jack.
#3 of 9 DanielBH
DanielBH
  • 27 posts
Posted June 05 2007 - 04:45 PM
Yep; the instruction manual says L / R; and the white/red ports along with the plugs on mine match up to the description and photo of RCA jacks at Wiki. The key for me is that "Y adapter" word! lol I should be able to find it now; thanks! :-D
#4 of 9 Marko Berg
Marko Berg
  • 856 posts
Posted June 05 2007 - 08:59 PM
You might want to make sure the TV's volume control also applies to the line level (red/white) output. My Sony CRT TV's volume control doesn't, and if I connected headphones to the TV set directly, the headphones would basically be blasting at full volume at all times.
If you have a receiver, you could run an audio cable from the TV's red/white outputs to an analog input in the receiver, and connect the headphones to the receiver. You could then use the receiver's remote to control the volume.
#5 of 9 ChristopherDAC
ChristopherDAC
    Producer
  • 3,729 posts
Posted June 06 2007 - 03:44 AM
You can also buy a set of headphones with a volume control, just a little rheostat in the middle of the cord.
#6 of 9 DanielBH
DanielBH
  • 27 posts
Posted June 08 2007 - 08:38 AM
Quote:
Got the Y-splitter, and it all works except for the volume control issue. I've tried the RCA input suggestions, and they don't work with my equipment; but I think I may have found another solution:
http://www.musicians....4&src=3SOSWXXA
It seems to be an in-line volume control adapter for headphones. I've had to buy a headphone extension cord given that my existing headphone wires are short, so I believe this or a like adapter could solve my problem; I would just plug the adpater into the extension cord, and then plug my headphones into the adpater.
Anyone have experience with these in-line adapters? It seems like it should be my solution; I was just wondering if you guys disagreed before I run and get one. Thanks again for all of this help! :-)
#7 of 9 Bob McElfresh
Bob McElfresh
    Producer
  • 5,183 posts
Posted June 08 2007 - 05:02 PM
Radio Shack sells extension cords and in-line volume controls.
My only concern is that this will give you 3 breaks in the wire and these connections are sometimes ... sensitive. I have had to tape some together to keep the connections working.
Glad to know you have a solution in the works.
#8 of 9 DanielBH
DanielBH
  • 27 posts
Posted June 08 2007 - 05:15 PM
Thanks! :-) Hopefully the sensitivity won't be a problem, but I'll cross that bridge when I get there. The extension cord I bought from Radio Shack is incredibly tight, so I can't imagine it being a problem; the in-line volume control ports are the question mark. It will probably be a week or so (about to leave on vacation), but 'll let you know how it turns out when I get back!
#9 of 9 DanielBH
DanielBH
  • 27 posts
Posted June 10 2007 - 05:17 AM
Just a quick note to let you know that everything works great! :-D I bought a "Volume Control Headphone Extension Cord" from Radio Shack, and the Fantastic Four Extended Cut sounded great! I'm not sure why Radio Shack calls this inline control an "Extension Cord", though; it's only about 8 inches long! lol
Thanks again for all your help! :-)
Forum Nav Content I Follow
