Jump to content
how do you get dts es and other sound formats?
3 replies to this topic
#1 of 4 leafswillwin
leafswillwin
  • 78 posts
Posted April 21 2007 - 07:49 AM
hey guys, just wondering my dvd player outputs with a digtal coaxial cable to my receiver. Should my reciever be able to decode the output for dts es and others or is that only possible through toslink and hdmi?
thanks
#2 of 4 Ed Moxley
Ed Moxley
  • 2,701 posts
  • Real Name:Ed
  • LocationEastern NC
Posted April 21 2007 - 08:21 AM
If your receiver supports it, it should play. Have you turned on DTS output in your dvd player's setup menus? For digital audio output, from dvd player, set to "Bitstream" or "Raw". Sometimes turning on DTS is an extra step, and you have to turn it "ON". Double check these things.
Also, you'll probably need to choose the DTS ES soundtrack, in the dvd movie's menus. It will usually automatically go to the DD soundtrack, but have to choose the DTS track.
Good luck!
Samsung HL61A750 (LED DLP)            Onkyo TX-SR805
Oppo BDP-83 Blu ray                                  Polk Audio LSi9
Polk Audio LSiC                                  Sony SS-MB100H
SVS PC12-NSD (Sub)                       ...
#3 of 4 leafswillwin
leafswillwin
  • 78 posts
Posted April 21 2007 - 09:16 AM
k i think i found it, thanks. so does that mean digital coax, toslink, and hdmi can support all these formats?
#4 of 4 Ed Moxley
Ed Moxley
  • 2,701 posts
  • Real Name:Ed
Posted April 21 2007 - 05:32 PM
yes........those are the ways to get 5.1 and 6.1/7.1 through digital O/I.
