Jump to content
PS3 Remote Problem
4 replies to this topic
#1 of 5 OFFLINE   JGiampa
JGiampa
  • 82 posts
Posted March 13 2007 - 04:51 PM
Ok so committed a sin. I opened the PS3 remote and threw out the package. Problem is how do you get it to work? I'm sure you need to set it up to the system but i cant figure out how. Normally you just put batteries in a remote and the thing works...no such luck here with the blu ray. Joe
#2 of 5 OFFLINE   SherardP
SherardP
  • 222 posts
Posted March 13 2007 - 10:28 PM
go into the settings of the ps3 and pair up the remote with the ps3, its easy. Takes less than 5 minutes.
#3 of 5 OFFLINE   John Garcia
John Garcia
    Executive Producer
  • 11,556 posts
  • Real Name:John
  • LocationNorCal
Posted March 14 2007 - 05:24 AM
Must have 1.50 firmware or higher installed or it will not work. Since it is a bluetooth device, you need to "register" it with your PS3. You turn on the remote with the PS button and then go into the menu as mentioned above.
HT: Emotiva UMC-200, Emotiva XPA-3, Carnegie Acoustics CSB-1s + CSC-1, GR Research A/V-1s, Epik Empire, Oppo BDP-105, PS4, PS3,URC R-50, APC-H10, Panamax 5100 Bluejeans Cable
System Two: Marantz PM7200, Pioneer FS52s, Panasonic BD79
(stolen) : Marantz SR-8300, GR Research A/V-2s, Sony SCD-222ES SACD, Panasonic BD-65, PS3 60G (250G)
Everybody is a genius, but if you judge a fish by its ability to climb a tree, it’ll spend its whole life believing that it is stupid.” – Albert Einstein
#4 of 5 OFFLINE   bassman99floyd
bassman99floyd
  • 95 posts
Posted March 15 2007 - 06:38 AM
You probably need to charge the remote. With the PS3 came a short, maybe 2' cord. Plug one end into the remote, the other end into PS3. Power on PS3 so it's fully on, and not in stand-by mode. Charge for a few hours. The PS button that was referenced above, looks like it's just a logo on the remote, but it is a button with a lot of functions. Push it in, and follow the on-screen instructions. Good Luck. Jimmy
The Man
#5 of 5 OFFLINE   Steve Schaffer
Steve Schaffer
    Producer
  • 3,759 posts
Posted March 15 2007 - 07:55 AM
The PS3 BD remote differs from the game controller in that it does not have rechargeable battery, just the normal AA batteries. You do have to do the bluetooth "pairing" procedure as described earlier.
Steve S.
I prefer not to push the subwoofers until they're properly run in.
