Jump to content
how to hide dvd and cable box?
6 replies to this topic
#1 of 7 OFFLINE   tspunk
tspunk
  • 2 posts
Posted March 09 2007 - 05:02 AM
Hi guys,
I was wondering if there was a way to do this:
I want to get an LCD to mount on my wall, but I don't want to put the dvd and cable box below it because i want it to be simplistic and clean looking.
Is there a product that let's me mount a sensor to the tv and then have the boxes under my bed or something? so when i point the remote at the tv, it's switching the channels on the box or controlling the dvd player that is under my bed or in a cabinet?
I'm not sure what my options are...
#2 of 7 OFFLINE   Ed Moxley
Ed Moxley
  • 2,701 posts
  • Real Name:Ed
  • LocationEastern NC
Posted March 09 2007 - 05:22 AM
You can get an RF remote, instead of using the usual IR remotes.
The RF remote will work through walls, with sources in another room.
Samsung HL61A750 (LED DLP)            Onkyo TX-SR805
Oppo BDP-83 Blu ray                                  Polk Audio LSi9
Polk Audio LSiC                                  Sony SS-MB100H
SVS PC12-NSD (Sub)                       ...
#3 of 7 OFFLINE   Jean D
Jean D
  • 1,329 posts
Posted March 09 2007 - 05:33 AM
you could also get an IR Blaster. which would do what your asking of it.
Gear: Crestron AADS, Crestron 4L, RTI T2C, SVS PC 16-46, Xbox 360, Wii, Bass Shakers, TiVo HD, Toshiba A3 HD-DVD, 42" Panasonic TH-42PWD8UK, two Denon AVR-2106's, Speaker Craft Aim 7 Five's, Samsung HD-950 DVD player.
#4 of 7 OFFLINE   Robert_J
Robert_J
    Lead Actor
  • 8,160 posts
  • Real Name:Robert
  • LocationMississippi
Posted March 09 2007 - 05:45 AM
Both Parts Express and Smart Home carry infrared distribution systems.
-Robert
#5 of 7 OFFLINE   tspunk
tspunk
  • 2 posts
Posted March 12 2007 - 03:02 AM
Quote:
-Robert
Hello Robert,
THanks for the website and info.
I went to smarthome.com and I am... overwhelmed. I clicked on the IR distribution link and find that i know nothing about the products listed.
Can you link me to exactly what i need (if possible and it's not too much trouble) to connect:
TV -> cablebox and DVD player.
with cablebox and dvd player hidden.
#6 of 7 OFFLINE   Paul Padilla
Paul Padilla
  • 767 posts
Posted March 12 2007 - 03:26 AM
I 've used the Hotlink Pro from Smarthome more than once. Very simple to set up and can control up to 8 devices.
I'm a ****ing idiot 'cause I can't make a lamp?
No, you're a genius 'cause you can't make a lamp.
What do you know about trigonometry?
I could care less about trigonometry.
Did you know without trigonometry there would be no engineering? Without lamps there'd be no light.
#7 of 7 OFFLINE   Robert_J
Robert_J
    Lead Actor
  • 8,160 posts
  • Real Name:Robert
Posted March 12 2007 - 07:33 AM
The cheapest and easiest to set up is the wireless "powermid". I got a similar product under the JVC name for $24 on Ebay. These are good products but not 100% reliable since they are prone to interference.
The wired product that Paul linked would be much more reliable but you will have to run cables through the wall.
-Robert
