Jump to content
Dove head first into HD. Help me not drown!
  • Please log in to reply
12 replies to this topic
#1 of 13 OFFLINE   JeffreyG
JeffreyG
  • 37 posts
Posted December 26 2006 - 12:33 AM
OK...so I took the plunge into HD and I am neck deep into it. Let's say I had an incredible Christmas. Here is my equipment: Panasonic TH-50PX600U (Thanks to my wife) Sony Playstation 3 (Thanks to my Dad!) Integra DTR-503 Reciever (had for a couple of years) Now here is my question...will my reciever work for this set up since I don't believe it has HDMI in/out? Both the Playstation and Panasonic have HDMI. Do I need to go out and get a newer Reciever? Or can I hook up the HDMI for the playstation directly to the TV for picture and then hook up the digital out of the playstation to the reciever for audio? Please help light the way. If I have to get a new reciever that handles HDMI, if you have any suggestions on a good, but reasonable model (I have about $300 in Best Buy Bucks!) that would be great! Thanks!
#2 of 13 OFFLINE   JeffreyG
JeffreyG
  • 37 posts
Posted December 26 2006 - 12:53 AM
Another question....does there seem to be a preference in here for what is the best HD content provider with DVR? DirectTV or Dish?
#3 of 13 OFFLINE   Bepaof8
Bepaof8
  • 45 posts
Posted December 26 2006 - 12:58 AM
Since no one else has responded, I'll try to help. I don't have a Playstation 3 (you lucky dog!), but do what you suggested - plug the Playstation into your TV for video, and into your receiver for sound. I have a new Yamaha "659", a JVC HD61FN97 LCOS HDTV, a HD-XA1 HD DVD player, a HD Cable box, etc., and that's what I do. Receiver for sound - TV for video. You don't have to have an A/V receiver with a HDMI connection. Pete ps. from what I've read here and elsewhere - Dish, with a box carrying the number "622". I've read about people complaining about DirectTV's compression (although I haven't any experience with it myself).
#4 of 13 OFFLINE   JeffreyG
JeffreyG
  • 37 posts
Posted December 26 2006 - 01:14 AM
Thanks! I could go cable, but I had a "I will never go with cable again" experiences. I was afraid I would have to shell out $500+ for a new reciever!
#5 of 13 OFFLINE   BrianShort
BrianShort
  • 934 posts
Posted December 26 2006 - 11:38 AM
You won't get Lossless PCM surround, but I'm just using the optical out from my PS3 and I'm happy with it. I guess I just don't know what I'm missing, so ignorance is bliss! Posted Image
#6 of 13 OFFLINE   Neil Joseph
Neil Joseph
    Lead Actor
  • 8,341 posts
  • Real Name:Neil Joseph
Posted December 26 2006 - 12:04 PM
Congrats, on the Christmas toys. Are you planning on doing a lot of gaming of mostly blu-ray movies with your ps3?
Click and enter " T H E . H O L O D E C K "
My Home Theatre "The Holodeck"
#7 of 13 OFFLINE   JeffreyG
JeffreyG
  • 37 posts
Posted December 26 2006 - 12:53 PM
Well, the Playstation 3 will be replacing the DVD player, so it will be what we view movies on. I am hoping that won't be a problem playing SD DVD on it.
#8 of 13 OFFLINE   Neil Joseph
Neil Joseph
    Lead Actor
  • 8,341 posts
Posted December 26 2006 - 01:06 PM
No problems. Do you have any BR titles yet?
#9 of 13 OFFLINE   Jeff Adkins
Jeff Adkins
  • 1,765 posts
  • Real Name:Jeff Adkins
Posted December 26 2006 - 04:13 PM
What Bepaof8 said. At least for the time being, Dish Network is the way to go for HD. Less compression artifacts, less HD-Lite, more channels, etc. It's not even close in my book. The 622 is a terrific DVR. I couldn't be happier. Congratulations on the PS3. I'm planning on getting one in a few weeks.
#10 of 13 OFFLINE   JeffreyG
JeffreyG
  • 37 posts
Posted December 26 2006 - 04:50 PM
Well....I have Talladega Nights. It came with the PS3. I will probably end up with DirectTV. I may jump on my father's commercial account and that is what he has. Plus it sounds like they will be having a ton of new HD "channels" when thost new satellites start up. As far as the artifacts, I know that the new HD DVR from DirectTV uses Mpeg4. Isn't that what everything is going towards? Here is another question. My plan was to have the Sat. Unit, HT Reciever, Playstation 3 and the VCR and move my DVD player elsewhere. Should I go ahead and hook my DVD player in this set up? Or will the Playstation 3 work fine as the player for both Blue Ray and standard def. DVD?
#11 of 13 OFFLINE   Matt Hough
    Executive Producer
  • 12,318 posts
  • LocationCharlotte, NC
Posted December 27 2006 - 10:32 AM
I haven't tried any standard DVDs in the PS3, but several reviews I have read say that the resolution is soft with standard DVDs (even though they're supposedly being shown at 480p like a traditional progressive scan DVD player would send to the TV). I'll tell you this, though. Today I watched THE SEARCHERS on Blu-ray using the PS3 and was blown apart by the image. Could NOT believe the three dimensionality of the image. TALLADEGA NIGHTS isn't reference quality video, even on Blu-ray, but THE SEARCHERS sure is.
#12 of 13 OFFLINE   JeffreyG
JeffreyG
  • 37 posts
Posted December 27 2006 - 12:25 PM
Thanks. That is great info. Maybe it is best to keep my DVD player in the mix for standard def. DVDs.....
#13 of 13 OFFLINE   4VTHOKIES
4VTHOKIES
  • 39 posts
Posted January 03 2007 - 02:06 PM
JeffreyG, I think keeping your SD DVD in the mix is a good idea especially if it upconverts to a higher resolution over 480p.
Also, do not listen to new receivers that have HDMI especially if they convert uncompressed audio to LPCM. Once you hear the difference between the uncompressed audio vs. regular DD or DTS you will definately not want to go back and you will have to spend the money on a new receiver. The audio quality with the new codecs is that good.Posted Image
