Jump to content
in-wall speaker wire question
6 replies to this topic
#1 of 7 OFFLINE   PeteE
PeteE
  • 64 posts
Posted November 28 2006 - 02:58 AM
hi all, I'm going to install some in-wall speakers and do I really need to use in-wall speaker wire, or can I just use regular 12g wire ? And if I need in-wall wire, can someone point me to where I can get some at a reasonable price. thanks
#2 of 7 OFFLINE   Andrew Pratt
Andrew Pratt
    Producer
  • 3,813 posts
Posted November 28 2006 - 03:03 AM
Pete wiring code dictates that you do need in wall approved wiring so you won't be able to use regular 12 gauge cable. Home Depot sells a 14 and 12 gauge approved cable though that is very affordable and is what most of my house is wired with.
#3 of 7 OFFLINE   DavidMich
DavidMich
  • 177 posts
Posted November 29 2006 - 10:00 AM
Wires not connected to the homes electrical supply are not subject to the same building codes as electricac wire. (Although codes vary by state,county,city, etc.) Regular 12g Speaker wire will do just fine. (Not the 12g romex wire used for wiring on the home). The stuff Home Depot sells on the spool is decent enough for most people.
The choices we make define our lives, because choice, not chance, determines destiny.
#4 of 7 OFFLINE   John Garcia
John Garcia
    Executive Producer
  • 11,556 posts
  • Real Name:John
  • LocationNorCal
Posted November 29 2006 - 10:36 AM
Check your local codes as to whether it is required or not; it may not be. The safest bet is just to get the in-wall rated wire.
HT: Emotiva UMC-200, Emotiva XPA-3, Carnegie Acoustics CSB-1s + CSC-1, GR Research A/V-1s, Epik Empire, Oppo BDP-105, PS4, PS3,URC R-50, APC-H10, Panamax 5100 Bluejeans Cable
System Two: Marantz PM7200, Pioneer FS52s, Panasonic BD79
(stolen) : Marantz SR-8300, GR Research A/V-2s, Sony SCD-222ES SACD, Panasonic BD-65, PS3 60G (250G)
Everybody is a genius, but if you judge a fish by its ability to climb a tree, it’ll spend its whole life believing that it is stupid.” – Albert Einstein
#5 of 7 OFFLINE   Philip Hamm
Philip Hamm
    Lead Actor
  • 6,885 posts
Posted November 29 2006 - 11:51 AM
www.partsexpress.com is where I have bought it.
Philip Hamm
Moderator Emeritus
#6 of 7 OFFLINE   PeteE
PeteE
  • 64 posts
Posted December 01 2006 - 05:41 AM
thanks for the input guys. I just purchased 200 ft of inwall wire from Blue Jeans so I am going to stick with that Pete
#7 of 7 OFFLINE   Blaine_M
Blaine_M
  • 400 posts
Posted December 01 2006 - 06:04 AM
As long as it is UL rated you are probably fine. I ordered all my cable from BlueJeans as well, if they say it is in-wall rated you should be good.
