Projector and up conversion DVD..will I really notice a differece? (1 Viewer)
Curt Luther
I have the Sanyo PLV Z2 projector and it has a DVI-I input. Would I be able to use a DVD player with up conversion on my projector? And if so, would I really see a big difference in video quality? I am currently using a Panasonic DVD player with component cables.
I am going to be buying a DVD recorder to transfer old movies to DVD and I thought I may as well buy one with up conversion if it will make a difference.
Any advice would be greatly appreciated.
Curt
Rob Mac
Ontario, Canada.
Rob
I have a Z3 projector and OPPO 981 with HDMI. I get a slightly sharper cleaner picture. Not a huge difference. I have been told by OPPO and Sanyo that using DVI adaptor can make the picture worse in some cases. If possible, buy from a store that will allow you to return the player if you are not happy with the result.
ChrisClearman
unless you spend a bunch of money on some of the top end players (and even then it's debateble) you will NOT notice a drastic difference in image clarity/sharpness/resolution vs a standard or progressive DVD player (assuming you are using Component/HDMI/DVI cables).
blitz
