Jump to content
Need Help! Center, surround speaker to match Infinity Beta 40
  • Please log in to reply
1 reply to this topic
#1 of 2 OFFLINE   vinay60
vinay60
  • 1 posts
Posted November 24 2006 - 08:34 AM
Hello, I am on a budget and I need recommendations for center and surround speakers to match Infinity Beta 40 (front right and left). Here's what I am thinking: 1. Center speaker Options - Beta C250, Beta C360 OR JBL Northridge EC35 Price Range - $150-200 Considerations: I am think of going with EC35. My first choice is really C360 but I don't think I will be able to convince my wife to fit that BIG unit in our living room. EC35 is also dicey (also pretty huge) but may be doable?! Size-wise, Beta C250 is probably the best option but since they cost same as EC35 I am leaning towards the 3-way speakers. Qs: 1. Am I making the right choice? 2. Will the tonal quality of EC35 (blk) match Beta40 (blk)? 3. Is there a better speaker you would suggest in the same price range? 2. Surround Options - JBL Northridge E20, Infinity Primus 150 OR ?? Price Range - $80-100 Considerations: I am thinking of staying away from Infinity Beta 20 (or 10) because of the price ($200+). Primus 150 has good reviews but not sure if I should go for E20s, specially if I pick EC35 for center? Qs: 1. Am I making the right choice? 2. Is there a better speaker you would suggest in the same price range? I have a fairly small room (12X15) and planning on getting a receiver HK AVR-240 (refurb, <$200) and Sony Subwoofer SA-WM250 (<$100) for the HT system. Since I haven't yet bought the receiver and subwoofer please do let me know if those aren't the best choice for the config in the price range? I am fairly a newbie and have budget/size constraints as mentioned above. Any help is appreciated? Thanks!
#2 of 2 OFFLINE   Alan M
Alan M
  • 454 posts
Posted November 26 2006 - 12:30 AM
Having your front three speakers match is very important. Getting a center from the same model product line as your left and right is the correct choice. It is possible to get a center from another brand to match,but it is difficult to do,and many "experts" for go attempting it.
