Jump to content
FS: Crestron MC2W Wireless system with remote
No replies to this topic
#1 of 1 OFFLINE   Todd_Brown
Todd_Brown
  • 396 posts
Posted October 29 2006 - 09:21 AM
I had to dismantle my theater to make a bedroom for my son. I am now selling my Crestron MC2W Wireless system and the ST1700C Color Touchscreen remote with docking station. This system sells new in the $3000.00 range. The system works perfectly, the remote has a brand new battery in it. The remote screen has some scratches, but no big deal.
The remote can be reprogrammed (it currently says Todds Theater, and is set for DVD, Laser Disc player, sat, lights, and curtains).
I listed the specs below. I am looking for $1500.00 plus shipping
MC2W Integrated Wireless Control System
Product Description
Key Features
Product Resources
Technical Specifications
Crestron 2-Series Control Systems are the brain of a complete integrated AV or automation solution. Every audio, video, and environmental element of the home, boardroom, classroom, or command center becomes integrated and accessible through the control system. Crestron 2-Series control systems are unmatched for power, performance and scalability, providing the ideal choice for today's demanding control applications.
The MC2W is a compact 2-Series control system with integrated 1-way RF gateway. Equipped with two built-in COM ports, four IR/Serial ports, four I/O Versiports, and four isolated relays, the MC2W is a great single-box professional RF wireless control solution for boardrooms, lecture halls, home theaters, churches, museums, and more.
Integrated RF Wireless
The MC2W's built-in RF gateway is switchable between 418MHz and 434MHz for compatibility with all of Crestron's 1-way RF wireless touchpanels and handheld remotes.
IR Wireless Option
When equipped with an optional CNXRMIRD IR receiver, the MC2W allows for IR wireless control using any of Crestron's IR wireless touchpanels, or a third-party universal IR remote.
2-Series Engine
At the heart of the MC2W is the powerful 32-bit Freescale ColdFire® processor. Crestron's exclusive enhanced real-time operating system makes the MC2W the fastest, most reliable control system available.
Cresnet®
Cresnet is the communications backbone for many Crestron touchpanels, keypads, lighting controls, and other devices. The Cresnet bus is a simple, yet flexible 4-wire network that provides rock-solid bidirectional communication for numerous Cresnet devices.
Cresnet Slave Mode
Selectable Cresnet Slave Mode enables the MC2W to be configured as a Cresnet slave device, effectively transforming it into a Cresnet expansion module. Such flexibility can offer a cost-effective solution for system expansion, providing a host of additional control ports in a single module.
2-Series engine
Cresnet port - master/slave selectable
2 Com ports (RS-232/422/485)
4 IR/serial ports
4 Versiport I/O ports
4 Low-voltage relay ports
Built-in 1-way RF wireless gateway
IR wireless compatible using CNXRMIRD
External power supply included
Single-space EIA rack-mountable
Crestron MC2W-C17PAK SmarTouch™ Control Package
This complete control package includes the ST-1700C color touchpanel, ST-DSN docking station, 2-Series MC2W wireless control system, ST-BTPN battery pack, (2) IRP2 infrared emitter probes and PW-2410RU power pack. It is an excellent choice for both commercial and residential applications.
Posted Image
Posted Image
Todd
P.S. Paypal is acceptable, e-mail me @ Todd66ovi@aol.com
My DVD Collection
