Jump to content
newbe, need help
4 replies to this topic
#1 of 5 bigtyme1
bigtyme1
  • 3 posts
Posted October 02 2006 - 01:11 PM
OK Guys, I'm working in the basement for a kids play room but want to think for the future. My plan is to have surround sound, big screen. I allready have a 60 big screen so that part is done. What I need to know is can I put the speakers in the ceiling?
What kind of wires should I run for future projector in the ceiling?
Can the front speaker go into the bulk head. About 7ft from floor?
Should I go 5,6,7,way surround?
Sorry if it's alot of info, I really don't know where to start. The plan is to have this room finished buy Xmas.
Mark.
#2 of 5 theflavor
theflavor
  • 3 posts
Posted October 03 2006 - 05:00 AM
I would always try to future-proof your setup, especially if you are finishing off the ceiling/walls and it won't be easy to get into it later.
As long as you have something sturdy to mounts your speakers to, you can mount them anywhere
#3 of 5 Stephen Williamson
Stephen Williamson
  • 8 posts
Posted October 03 2006 - 01:57 PM
Only if you have to, and then only the rears, in ceiling speakers throw out the surround effect.
HDMI, Component, Power Or better still, just a big conduit with draw string
If they are in wall speakers then yes, however, try to find speakers with moveable tweeters to help sound direction, do not put normal bookshelves in a niche unless they are designed for the task. Center speaker should be as near to the cneter of the screen as possible.
Speaker cable is cheap, run for 7.1, allow for different positions of the subwoofer along with power outlets.
#4 of 5 bigtyme1
bigtyme1
  • 3 posts
Posted October 04 2006 - 02:47 PM
This is great info, Thanks for all the help. should I be running 16 gauge for all the speakers?
#5 of 5 homthtr
homthtr
  • 519 posts
Posted October 04 2006 - 02:54 PM
16 is ok 14 would be better. Look for a high Strand count wire. If using 16guage look for a strand count of 65 or more.
