Carl Johnson
- May 6, 1999
- Carl III
I'm debating what features to include in the build to order PC that I'm going to order from tigerdirect.com. I know enough these components to make a decision on my own.
processor Intel Pentium D Processor 945 3.4GHz Dual Core
memory 1GB DDR400 PC3200 Memory (1GB x 1)
hard drive 320GB 7200RPM 3G SATA II
optical drive16X DVD+/-R/RW Dual Layer Drive w/Cyberlink
A large part of my motivation for going with tiger direct instead of Dell is having the option of upgrading or if necessary repairing myself. I want to stay away from integrated components but for the purposes of basic web surfing I assume that I can get away with entry level audio and video cards
audio SoundBlaster Audigy SE Sound Card
video GeForce FX5200 128MB AGP (1VGA)
The components I'm not sure about are the modem, network adapter, and firewire card. I'm connecting to the net via cable modem thru a router so that my girlfriend and I can both be connected. My first choice is the following for network adapter because it's the cheapest non integrated option
10/100/1000 Gigabit PCI Adapter
For a grand total of $740.00
Do I need a modem
56K V.92 PCI Modem $8.00
or a firewire card?
3-Port Firewire PCI Card $12.99
If any of the components are useful but optional I could order then a la carte and install them myself. Any advice is much appreciated (even if it's get a Mac instead )
Do I need a modem
or a firewire card?
