Jump to content
Hammermill Business Card Stock... help?
  • Please log in to reply
2 replies to this topic
#1 of 3 OFFLINE   Scott Wong
Scott Wong
  • 421 posts
Posted September 04 2006 - 09:11 AM
Got some Hammermill linen business card stock on eBay. Standard 8.5" x 11" sheets. Good price. Using our HP Officejet 5610 printer... the cards will not print properly and line up. The cards are formatted in MS-Word and they line up perfectly on the templates supplied by Hammermill. However, are putting in the linen card stock - the business cards print out differently each time. They never line up properly as the way they seem to on normal paper, i.e., the template. What in the world is going on? Has anyone done this before? Why would the way these cards are lining up in MS-Word be different when using the business card stock? Is it a hardware issue with the printer... or a software issue with MS-Word? Help or suggestions?
#2 of 3 OFFLINE   Glenn Overholt
Glenn Overholt
    Producer
  • 4,207 posts
Posted September 04 2006 - 10:35 AM
I'm not sure this will help, but Word is going to be screwed up unless it has the template format sent to the printer. If the Hammermill card stock is the same size as the Avery ones, you could get Word to set that up - it is under envelopes and labels, but you'll have to get the correct Avery label number. One of them is # 5376. Good luck! Glenn
#3 of 3 OFFLINE   Scott Wong
Scott Wong
  • 421 posts
Posted September 04 2006 - 11:26 AM
Glenn: Awesome info... I'll do some snooping around in MS-Word and see how it goes. This should do the trick!!
