Jump to content
Sign up for a free account!
Accessing my HT components in a heavy cabinet
2 replies to this topic
#1 of 3 bluet1
bluet1
  • 2 posts
Posted July 27 2006 - 05:09 AM
My HT components are in a typical entertainment center cabinet which has two towers and a separate "bridge" that connects the two. This center is on carpet which makes it difficult to move the heavy furniture if I need to get behind my components for wiring, etc. I wondered if anyone knew of a good product or way to either move this type of furniture on carpet easier or to access the components more conveniently. Thanks!!
#2 of 3 Lance.G
Lance.G
    Extra
  • 20 posts
Posted July 27 2006 - 09:37 AM
http://www.redhotcar....nt-slides.html
These make moving anything on carpet very easy.
#3 of 3 Don.l
Don.l
  • 118 posts
Posted July 28 2006 - 07:23 AM
Yes. You don't necessarily have to get those. You can go to the Home Depot and get things like that. They make moving heavy things easy. Another option would be to considter putting casters on the bottom. It's a little more work in that you would have to take everything off, turn it on it's side and install the casters. Then once you get it upright you would have to hide the casters with molding or something like that. More work, but really easy to move.
Don
