Jump to content
Acura TL CD player problem.
  • Please log in to reply
4 replies to this topic
#1 of 5 Jay H
Jay H
    Advanced Member
  • PipPipPip
  • 5,619 posts
  • Real Name:Jay
  • LocationPittsfield, MA
Posted July 26 2006 - 03:40 AM
My father has a '02 Acura 3.2TL, the CD player in the dashboard is reading an E-01 code and not ejecting the CD, anybody know the proper way to manually get the CD out?
Do you think the manual will mention something of this? The car is out of warantee too so not trying to go to the dealer.
Jay
You are the crispy noodle in the vegetarian salad of life
#2 of 5 Alon Goldberg
Alon Goldberg
    Advanced Member
  • PipPipPip
  • 1,131 posts
Posted July 26 2006 - 03:45 AM
Well.. the 2006 Acura TL has a DVD-Audio player, so just tell your mom that your dad needs an "upgrade". Posted Image
#3 of 5 Chad_K
Chad_K
    Member
  • PipPip
  • 20 posts
Posted July 26 2006 - 04:00 AM
I would not suggest trying to manually pulling ths cd out. If you have the security code for the radio I would try disconnecting power to the unit to reset it. If that does not work then you are pretty much going to have to look at a replacement.
Chad Kemp
Technologist,
A/V Connections Inc
Little Rock, ARchadkemp@sbcglobal.net
#4 of 5 Jay H
Jay H
    Advanced Member
  • PipPipPip
  • 5,619 posts
  • Real Name:Jay
Posted July 26 2006 - 05:42 AM
OK, I try the hard boot... My father does have a DVD drive, but I think that is in the trunk because that is for the Navigation option, which he has. However, I think it has an in-dash CD player that is the culprit here.. It's been a while since I've been in it though...
Jay
#5 of 5 EvanW
EvanW
    Advanced Member
  • PipPipPip
  • 233 posts
Posted August 08 2006 - 10:39 AM
uh, watch out before u reset the power to the car, u might do more damage then good, if ur dash decided to reset, thats not always good.
