Jump to content
Trouble With Punisher & Saw
  • Please log in to reply
15 replies to this topic
#1 of 16 OFFLINE   Terry-A
Terry-A
  • 46 posts
Posted June 27 2006 - 11:55 PM
i just viewed T2 Punisher and Saw...Punisher and Saw had skips and dropped frames...punisher was the worse with skips every 30 seconds...Saw wasnt as bad but still had skips through out the movie...any one have this problem with Punisher or Saw....T2 wasnt bad but has a little grain in it and backgrounds could of been sharper....not bad for an older movie....i still think HDDVD is better....
#2 of 16 OFFLINE   Jack Briggs
Jack Briggs
    Executive Producer
  • 16,727 posts
Posted June 28 2006 - 03:49 AM
Huh? Are you talking about HD DVD releases? I do not recall these titles being released into the HD DVD format.
#3 of 16 OFFLINE   Walter Kittel
Walter Kittel
    Producer
  • 4,910 posts
Posted June 28 2006 - 04:13 AM
Jack, Terry is referring to the Blu-ray releases from Lionsgate.
Terry, There is a thread over at AVS discussing this issue with titles from Lionsgate. One of the reviews over at High Def Digest also mentions a stutter with regards to Saw. I do not know how prevalent this stuttering might be, but it has been reported by others. ( Also, is it an issue with the Samsung player or the media? )
Rachael B's thread over at AVS
- Walter.
Fidelity to the source should always be the goal for Blu-ray releases.
#4 of 16 OFFLINE   Steve Blair
Steve Blair
  • 380 posts
Yep, there's trouble with the Lion's Gate titles too per avs. Seems that probably due to compression or something else there are dropped frames during the film, stuttering when the camera pans, etc.
#5 of 16 OFFLINE   Roger Mathus
Roger Mathus
  • 557 posts
  • Real Name:Roger Mathus
  • LocationCentral Oregon
Posted June 28 2006 - 04:16 AM
Although I only sampled each chapter on Punisher and Saw I experienced no such glitches.
#6 of 16 OFFLINE   Terry-A
Terry-A
  • 46 posts
Posted June 28 2006 - 04:19 PM
i think its just the software...i have all the movies on blu ray and saw and punisher were the only 2 i had the dropped frames with....underworld was spectacular and i got good quality out of 5th element,when i went to BB and CC the blu ray looked horrible on the 1080p samsung TV's...when i got the sammy home hooked up to my sony 1080i KDS-R50XBR1 the results were spectacular....i also have the toshiba XA1 that i love also....
#7 of 16 OFFLINE   Terry-A
Terry-A
  • 46 posts
Posted June 28 2006 - 10:40 PM
thank you for the link to the AVS site Walter...seems like alot of people are having the stuttering problem....Amazon is sending me a new saw and punisher...i should get them today and will post the results i have with them... REMEMBER: YOU KEEP WHAT YOU KILL so for now im not killing my blu ray because i might have to keep it
#8 of 16 OFFLINE   Steve Phillips
Steve Phillips
  • 1,526 posts
Posted June 29 2006 - 02:55 AM
It was very obvious on THE PUNISHER. The only other Lions Gate Blu-ray I have is TERMINATOR 2, which did not seem to have a problem.
#9 of 16 OFFLINE   Roger Mathus
Roger Mathus
  • 557 posts
Posted June 29 2006 - 08:09 AM
I just viewed The Punisher in its entirety. I detected no skipped frames. I did, however, see very slight stutter on one pan scene. I am watching with Marantz projector and 8 ft screen. I used the DTS sound track.
#10 of 16 OFFLINE   Terry-A
Terry-A
  • 46 posts
Posted July 02 2006 - 02:00 AM
i just recieved another punisher and saw from amazon and had the same response....i dont call it stutter i call it dropped frames....its skipping frames while going to the next scene....probably too large of a movie for single layer blu ray...its only on saw and punisher for all my blu ray movies and i have them all..had the same problem with freeze skipping and all that happy horse crap with my toshiba XA1 which was march built....got another one and it worked flawlessly...i also spent 2 hours hooking it up to component and the effect was the same....sent saw and punisher back to amazon for a refund...i can do without those 2 movies anyway....
#11 of 16 OFFLINE   Rachael B
Rachael B
    Producer
  • 4,637 posts
Posted July 02 2006 - 07:40 AM
Terry, choose DD instead of DTS for audio and the judder will likel;y be gone. That worked for me with T2 last night. If Samsung can't fix this, or if Lionsgate's discs aren't recalled, my Samsung will proably go back.
Rachael, the big disc cat is in real life Dot Mongur, Champion of the International Pacman Federation. You better be ready to rumble if you play Jr. Pacman with me. This is full contact Pacman and I don't just play the game, I operate it!
#12 of 16 OFFLINE   Terry-A
Terry-A
  • 46 posts
Posted July 03 2006 - 10:54 AM
thank you thank you thank you Rachael B,
your little trick worked by switching to DD.....and actually the sound was almost the same on DD....DTS was a little crisper and the center channel was clearer....it worked for punisher now to try saw......
thank you againPosted Image
#13 of 16 OFFLINE   Steve Phillips
Steve Phillips
  • 1,526 posts
Posted July 06 2006 - 03:02 AM
I tried this last night. It worked! By switching to the DD audio tracks, the discs now play fine with no studder.
#14 of 16 OFFLINE   Dave Mack
Dave Mack
    Producer
  • 4,665 posts
Posted July 06 2006 - 09:14 AM
Is this acceptable? If I had a regular DVD that did that, I would return it. If it were the player's fault, I'd be pissed after dropping $1K....
#15 of 16 OFFLINE   Steve Phillips
Steve Phillips
  • 1,526 posts
Posted July 06 2006 - 09:29 AM
Not acceptable, but at least I can watch the movies without studder now. Considering I'm renting most of this stuff from netflix anyway, I can live with it until they fix the issue.
#16 of 16 OFFLINE   Dave Mack
Dave Mack
    Producer
  • 4,665 posts
Posted July 06 2006 - 12:14 PM
Rentals, got it.
Posted Image
