Jump to content
Newbie questions for possible front projector purchase??
  • Please log in to reply
8 replies to this topic
#1 of 9 OFFLINE   Ian B
Ian B
  • 101 posts
Posted May 14 2006 - 04:00 PM
Hi gang; Now that I got an HD DVD player and a blu-ray player on order, I am considering getting a front projector under 3K. I would like it to be 720p/1080i native, DLP and HDTV ready with DHMI connection. I mostly watch Time Warner HDTV DVR recorded programs(60%). If it is 4x3 , I stretch the image, some video gaming(10%) and widescreen dvds(30%). Room size: 11' wide by 13" long Light fully controlled Projector mounted from 9" ceiling dead center at the back of the room Screen size: Not decided yet but, will appreciate any size and aspect ratio recommendations. Possible projector: InFocus 76 Can I get a quick definition of 720p and 1080i native resolution and how that will impact watching HD content? Thanks, Ian B
Ian B.
#2 of 9 OFFLINE   Rob||Kur||
Rob||Kur||
  • 112 posts
Posted May 15 2006 - 09:31 AM
As far as I know, you're stuck with native 720p at that price point. I don't think there are any 1920x1080 native projectors under 5 figures right now. A native 720p projector will still give you a very nice image in 720p or 1080i.
Sanyo PLV-Z3 720p Projector, B&K Reference 20 Processor, Parasound HCA-855A Amplifier, Pioneer Elite DV-45A DVD Player, Swan 6.1 Mains, Mordaunt-Short Center Channel, KEF Q15 Surrounds (for sale)
Looking for: Swan C3 Center and R3 Surrounds
http://www.neweconomydesign.com/http://www.needmusic.com/
#3 of 9 OFFLINE   SamNavy
SamNavy
  • 50 posts
Posted May 15 2006 - 12:09 PM
Go get the latest copy of Sound and Vision Magazine, they just had a "Budget" projector shootout. The article should get you pointed in the right direction.
#4 of 9 OFFLINE   Ian B
Ian B
  • 101 posts
Posted May 15 2006 - 02:10 PM
Thanks for the info. I had looked at that article and am very interested in the Infocus 76. Any experiences or word of mouth on it? Thanks again, Ian B
Ian B.
#5 of 9 OFFLINE   SamNavy
SamNavy
  • 50 posts
Posted May 15 2006 - 02:50 PM
Sorry, I don't have experience with any of the projectors in the article, but they're all 720p LCD or DLP... I would suggest however, that before you spend $2400 on the IN76, you check it out next to the Panny 900u, currently avail for $1800 w/$400 rebate. If you see them side-by-side and can tell a $1000 difference... you make more money than most of us.
#6 of 9 OFFLINE   JohnnyZ
JohnnyZ
    Extra
  • 20 posts
Posted May 16 2006 - 11:20 PM
As Rob said, that price point is 720p equipment. But the Sanyo Z4 is very nice. Google for the reviews on it. $1700!
#7 of 9 OFFLINE   JohnnyZ
JohnnyZ
    Extra
  • 20 posts
Posted May 17 2006 - 10:52 PM
The Sanyo Z4 is 720p and very nice. Only $1700. Check out the various on-line reviews!
#8 of 9 OFFLINE   PhilDi
PhilDi
  • 3 posts
Posted May 22 2006 - 08:29 AM
With all due respect to SamNavy, if you saw the IN76 and the Panny 900u side-by-side you would see considerable difference in the picture characteristics. Note that I said "characterisitics" and not "quality". This was intentional since both represent excellent picture "quality" for the money. But the picture "characteristics" are quite different. The IN76 has the typical DLP-type punchy picture, and the 900u has the typical LCD-type picture, which many describe as more film-like. It is totally a choice based upon personal preference, because when each is matched with the right screen/room combination, they are great. Personally, I prefer the DLP projectors - but that's me. BTW - I'm a dealer and sell both of these projectors, so I'm not biased one way or the other. I don't think that you could go wrong with either one. Hope this helps, Phil
#9 of 9 OFFLINE   Shane Harg
Shane Harg
  • 291 posts
Posted May 22 2006 - 10:38 AM
If it were me, I'd be basing the the decision on screen size and approximate viewing distance. Do you know the screen size you want yet? The room is 13' long, but do you know what your net viewing distance will be? A good rule of thumb I have found (in doing a lot of FP research myself) is that if you will be viewing 100" or more from a distance of less than 10', something with a more film-like picture (so you won't see inidividual pixels), such as the Panasonic AE900 may be a more appropriate choice. If, however, you will be viewing the same size image at more than 10', something with better pixel separation (and therefore a more razor sharp image), such as the IN76 or Sanyo Z4 may be a better choice. I believe that the AE900 is just about the only projector capable of projecting an image size of 100" at less than 10', anyway. whatever the size, I recommend a 16x9 screen for best versatility.
"BE the miracle!"
