DVR Remote Control For Time Warner Cable - Channel Change Question (1 Viewer)
Derek K.
Anyone know how to program the remote so that when you enter a channel (Lets say '123') you dont have to press 'Select' afterwards (The channel would automatically switch after entering the whatever channel you want).
Mike Frezon
Rexford, NY
Derek: Would it work to enter the channel as a four-digit number? To use your example, enter 0-1-2-3? That's what I do with my HD converter box remote.
My digital cable provider has stations that go up into the four digits...so after you've entered the fourth digit, the station automatically pops up.
Good luck.
acinstallation715
