Portable DVD Player Connection to AV Receiver? (1 Viewer)
chadP
How do I connect my Polaroid PDV-0820 DVD player to my Sony A/V Receiver? It says Optical out on the player but has a RCA type connector. Is there an accessory or adapter to make this compatible with the Optical connector on the receiver?
Any help appreciated. Not really a necessity but would like to know.
Robert_J
Mississippi
From the description at Amazon.com there is no optical output. There is coax output. If you only have optical inputs on your recever, then you need a coax to optical converter. Those are available from PE for under $20.
-Robert
acinstallation172
