Crackling Noise with Sirius Satellite Radio (1 Viewer)
ron.diamond
I have a vexing problem with my Sirius radio sound quality that's driving me nuts! Any ideas for fixing the problem would be greatly appreciated.
I use an Audiovox plug n play unit in a home docking unit that I connected to my Elan home sound system. The problem is a terrible crackling noise when I listen to Sirius radio in my home. It sounds like someone's frying bacon in the system - the louder the volume, the worse the noise. I can't figure out how to make the noise stop. Now, here are some additional details...
When I use the system in the car, the sound is crystal clear. Also, if I listen to the unit with ear buds while it's docked in the house, the sound is crystal clear. Therefore, I don't think the radio is the problem. It's only when I connect the system to my Elan system that I hear the "frying bacon".
Lest you think you have a solution already, please read on. I also have a home theatre system, CD player, and FM Tuner also hooked up to my Elan system. None of these sources have the "frying bacon" crackling noise problem. They all sound great.
A few months ago, a friend recommended a ground loop isolator to resolve the problem. It actually worked great - except that the problem seems to have slowly returned. I then put ground loop isolators on the other sources, but this did not help.
I turned the Audiovox system's FM transmitter off. This did not help.
I have an inline amplifier to boost the signal coming out of the Sirius radio and into the Elan system amplifier. I disconnected this, but it did not help.
I have an outdoor antenna for my sirius unit and needed two 30 ft antenna extensions to get from it to my home docking station location. I generally have a good signal at three bars, sometimes two. This doesn't seem to make a difference.
Can anyone suggest what the problem could be and how to make it quit?!?!?
Ernie Estrella
San Diego, CA
Ernie
I plug an external multi media speakers directly into my audio out home dock for my Sportster and it works crystal clear. When I try to tune in with my home theater downstairs, I sometimes get the fuzzy signal. Most of the times you can just tune into another station as the one you've chosen has tendency to pull the info from a strong staion nearby. I've had that static before and just changed the station to something else, retune my other radios and it sounded great.
But for my home dock set-up, just plug some nice speakers you would normally hook up to your computer with a subwoofer set (usually $30-50) and it sounds phenominal. I have no amplifier, and nothing to supe it up any.
ron.diamond
Thanks for your response Ernie. Unfortunately, I'm not using the FM transmitter in my Sirius radio - I'm using the audio output from the home docking station directly into my Elan home sound system.
I do have a correction to my original post though. I am getting the noise through the audio output. This is different than the first time I had this problem. I suspect a ground loop problem somewhere...
Erick.S
I hope you get the problem resolved. I don't have crystal clear audio on my sirius unit when i'm in the car because I use the fm transmitter. When people pronounce the letter S it sounds fuzzy and sharp at the same time. Odd. So I understand how annoying a problem can be. Anyway, good luck.
Ernie Estrella
San Diego, CA
Ernie
Erick,
have you tried other blank stations? Sometimes you get a crackle because your car antenna is pulling a local station that's pretty strong, or a nearby station. Sometimes Iget a crackle and then tune it to another station and it comes in crystal clear. I've had it for 5 months now and I get great reception.
acinstallation172
