HDMI Switch Problem (1 Viewer)
Mark Abrams
I recently purchased a Gefen HDMI 2x1 switch so that I could
connect both my DISH Satellite Receiver and my Panasonic S97S DVD Player to my Samsung TV, which has only 1 HDMI input. The output from the satellite receiver is DVI, so am using a DVI-to-HDMI cable for that connect into the switch.
I can get a picture from the DVD player but the satellite
doesn't go through. When I called the electronics store
from whom I bought the switch, they asked whether my DISH 811 Receiver was HDCP compliant (not exactly sure what that means) -- I called DISH and they didn't seem to have any clue as to what HDCP compliant meant. Anybody ever have this problem,
and are there certain HDMI switches that will work with satellite receivers and others that won't?
Jerome Grate
I thought I recalled reading in this forum that HD satellite issues were via HDMI was caused by HDCP. HDCP is High Definition Copy Protection which prevents recording high def material on to HD capable recording material. Do a search on this forum and I think you'll find the exact answer.
blitz
