Jump to content
How to use my rear projection HDTV as monitor
7 replies to this topic
#1 of 8 OFFLINE   RentBaxley
RentBaxley
  • 35 posts
Posted January 15 2006 - 10:32 AM
I am in the market for a new PC with windows media center. I want to use it in my living room for all music/movies etc. I am goign to get one with dual tuners etc. Is there anything special i need to look for in order to use my Mitsubishi HDTV as the monitor? This TV is about 3 years old and does NOT have a DVI input.
Any thoughts? I am also looking for suggestion on a PC. I would like to keep it around 1K. currently looking at a Dell.
Thanks!
#2 of 8 OFFLINE   JohnMurphy
JohnMurphy
    Extra
  • 16 posts
Posted January 15 2006 - 11:29 AM
Just make sure the video card has a video out then you can run a cable from the card to the back of the tv. I made the mistake thinking that my new media center had one because my old media center had one. I was wrong. Now I have to get a new video card to make it happen.Posted Image Murph
#3 of 8 OFFLINE   RentBaxley
RentBaxley
  • 35 posts
Posted January 16 2006 - 12:06 AM
Thanks for the input.
Any suggestions on a computer manufacturer? At this point i am goign to go with the dell outlet.
#4 of 8 OFFLINE   JohnMurphy
JohnMurphy
    Extra
  • 16 posts
Posted January 16 2006 - 12:21 AM
I bought an HP media center from Best Buy.
I havent had and problems with it. I like to use their money for two years. Just my opinion. Murph
#5 of 8 OFFLINE   John S
John S
    Producer
  • 5,460 posts
Posted January 16 2006 - 02:02 AM
Does the Mits have VGA input? If so, that sure makes it simple.
#6 of 8 OFFLINE   RentBaxley
RentBaxley
  • 35 posts
Posted January 16 2006 - 02:09 AM
Nope, no VGA input.
#7 of 8 OFFLINE   John S
John S
    Producer
  • 5,460 posts
Posted January 16 2006 - 02:16 AM
I'm not aware of the options available to you.
I have never hooked up a display from an HTPC with a Component Video Connection. Others may have though.
I'd say the display is not what I would consider a prime candidate for HTPC use, but it may be possible still, I just have not had to do it.
#8 of 8 OFFLINE   RyanCC
RyanCC
    Extra
  • 20 posts
Posted January 16 2006 - 07:35 AM
if you get it to work, be mindful that rear projection tvs can get screen burn in.
