Jump to content
Sign up for a free account!
Signing up for an account is fast and free. As a member you can join in the conversation, enter contests and you won't get the popup ads that guests get. Click here to create your free account.
Help for Sirius noob?
4 replies to this topic
#1 of 5 DarrenAlan
DarrenAlan
  • 172 posts
Posted January 12 2006 - 10:24 AM
Hey guys (and gals, if there any reading),
Right now I get Sirius satellite radio via my subscription to DishNet. And I have enjoyed it immensely, especially the classic jazz station and Les Davis.
However, for a number of reasons, the most critical being DishNet's lack of HD programming and my inability to get OTA due to topography, I'm thinking of switching to cable.
I have satellite dishes (two), HDTV OTA antennas, etc., as well as exterior cabling running right to where my two systems (one music only, the other dedicated HT) reside -- what else do I need, specifically, to continue receiving Sirius satellite radio?
Besides a subscription, that is.
Thanks in advance for the help!
#2 of 5 Brent T
Brent T
  • 279 posts
Posted January 12 2006 - 12:18 PM
I have DirecTV with HDTV and I have my sportser plugged right into my Integra. Sounds great. As long as you can get the antenna outside you shouldnt have any problems. I just ran mine along the wall. I did buy the extension for it though.
#3 of 5 DarrenAlan
DarrenAlan
  • 172 posts
Posted January 12 2006 - 12:24 PM
Thanks, Brent. Just to clarify for any future readers, I don't care too much about mobile audio; this is just for my home systems. The clarity I get right now is outstanding -- does anyone know what Sirius uses for a source ... CDs? DVD-Audio? -- and I don't want to lose that.
Additional specific recommendations welcomed!
#4 of 5 Jeff Gatie
Jeff Gatie
    Lead Actor
  • 6,529 posts
Posted January 12 2006 - 01:03 PM
Sirius uses a proprietary compression technique to broadcast. They probably use computers for sources, PCM or high bitrate MP3. In order to get Sirius without your Dish, you need the following:
A Sirius Radio - There are plug and play (go from car to home, need a dock of some sort in each location) which broadcast via FM mod or mini-plug cable to existing receivers, Car only (usually a box that cables into a head unit) and Home only (Kenwood makes one for use with a stereo/HT and Tivoli makes a real nice table radio)
An antenna - You need to place this in a window or mount it to the side/roof of the house. There are different pointing recommendations according to your geographic location. Every radio comes with a basic antenna and there are home specific antennas available if the standard one is not sufficient (mine is a standard car antenna in a north facing window sill and I get 2 out of 3 bars and a full terrestrial signal). Terrestrial signals are from land based sat repeaters and are located around major cities.
A subscription - Monthly is 12.99, Buying multiple months/years give you a discount.
You can read this all on the WWW.sirius.com under the "How to get it" tab.
#5 of 5 DarrenAlan
DarrenAlan
  • 172 posts
Posted January 12 2006 - 05:00 PM
Jeff, you da man.
'Nuff said.
Many thanks.
