Jump to content
Best "bitrate" for audio quality ? (dloading from internet)
  • Please log in to reply
4 replies to this topic
#1 of 5 OFFLINE   Kevin_Breeze
Kevin_Breeze
  • 304 posts
Posted January 09 2006 - 02:21 PM
Is higher better or lower?? Most are 128 but some are quite a bit higher and others are lower. Whats the best audio quality for burning to CD's, higher or lower??
#2 of 5 OFFLINE   Dick Knisely
Dick Knisely
  • 372 posts
Posted January 09 2006 - 02:49 PM
Higher is better. 128kbs is usually considered to be the minimum to be CD quality for MP3s, tho' personally I don't think anything under 192k sounds as good as a CD. There's no best per se -- well, actually the best would be a lossless compression rip to a .wav file or similar format. The penalty, of course, is file size. Personally, I use a variable bit rate setting with the min at 160k and the max at 320k.
I am not young enough to know everything. -Oscar Wilde-
#3 of 5 OFFLINE   Kirk Gunn
Kirk Gunn
  • 1,612 posts
Posted January 10 2006 - 01:25 AM
192k here also !
#4 of 5 OFFLINE   Herschel
Herschel
  • 94 posts
Posted January 10 2006 - 01:29 AM
I'm surprised you're seeing a lot of 128kbps out there. Pretty much everyone agrees that's not high enough to sound good. 192kbps is a good minimum, preferably VBR.
#5 of 5 OFFLINE   Scott Merryfield
Scott Merryfield
    Executive Producer
  • 10,889 posts
  • LocationMichigan
Posted January 10 2006 - 05:34 AM
See my reply to the same thread you posted in the Audio/Video Sources forum. FYI, it's generally frowned upon the post the same question in multiple forums here.
