Jump to content
Sign up for a free account!
Sat. Radio Audio Level
4 replies to this topic
#1 of 5 Tyler Merrick
Tyler Merrick
    Extra
  • 24 posts
Posted January 01 2006 - 12:50 AM
I just got a sat radio and my old cd player doesnt have a aux input so I am forced to run it as FM. My problem is the audio level between CD and radio is quite different. So if I am playing a CD first and its at a loud volume then switch to FM it is much quieter.
Is this because of:
1 - Old CD player doesnt bring in FM very well
2 - FM Signal just isnt as strong
Finally would this be fixed if I could use a aux input? I have used the audio level adjustment on my Sat. Radio device , but it doesnt go high enough.
Tyler Merrick
www.tylermerrick.com
#2 of 5 Andy Hardin
Andy Hardin
  • 99 posts
Posted January 09 2006 - 08:26 AM
It probably has to do with how your FM modulator is sending the signal. I've got two cars, one I'm using an FM modulator for my XM radio and one XM is built into the head unit.
On my FM modulated signal I have the *exact* same issue as you do. I think it is just a part of the game. The signal those modulators send is "quiet". The only way I can see to get around it is to updgrade to integrated components. I have no issue with this on my integrated Head Unit.
#3 of 5 Tyler Merrick
Tyler Merrick
    Extra
  • 24 posts
Posted January 09 2006 - 08:30 AM
By intergrated do you mean a unit that does sat radio thru the head unit?
I think using an aux input should solve it as well right? Which for me also means a new head unit.
Tyler Merrick
#4 of 5 Spencer M
Spencer M
    Extra
  • 23 posts
Posted January 09 2006 - 10:16 AM
Tyler you are correct. Any aftermarket head unit with a aux input or (sat radio capable)will work..for example with say a Pioneer head unit you would want a radio that is a (P bus) radio has the letter P (DEH-P3700mp) in the model number
#5 of 5 EvanW
EvanW
  • 233 posts
Posted April 28 2006 - 09:51 AM
If ur using a fm transmitter its the mp3 players fault lol, not anything else called a 1 volt 1/8 out, solution, like voltage gain or in like headphone amp to step up the voltage, or hardwire it, u can use 1/8 to rca's but i dunno if ur head has rca in's, or u can use an antenna plug to dual female rca's and a 1/8 inch to male rca interconnect but u lose ur fm and am radio.
