Jump to content
Sign up for a free account!
Signing up for an account is fast and free. As a member you can join in the conversation, enter contests and you won't get the popup ads that guests get. Click here to create your free account.
Satellite receiver out to Samsung 61" 1080p HDTV?
3 replies to this topic
#1 of 4 zak
zak
    Extra
  • 22 posts
Posted November 08 2005 - 12:20 PM
I just purchased the new Samsung HL-R6168W 1080p HDTV.
The TV has two HDMI inputs but no DVI inputs.
I need to purchase a new HD satellite receiver but the Motorola DSR505 only has the following video connections:
-Digital Video Interface (DVI)
-YPbPr Component Output
-S-Video
-RCA composite video
-Coaxial cable
Should I run a DVI to HDMI cable from the Motorola and use up one of my two HDMI connections or should I use Component or S-video instead leaving the HDMI free for future hardware.
One HDMI connection has already been reserved for future HDMI DVD player.
Will component or S-video connection from Satellite receiver look as nice on the Samsung as a DVI to HDMI connection?
Zak
#2 of 4 John S
John S
    Producer
  • 5,460 posts
Posted November 09 2005 - 06:24 AM
Component carries HD, svideo only carries NTSC, and not so good NTSC compared to component at that.
So no svideo, you have to actually try both component video and DVI/HDMi and see which is better or just plain note the difference to see which way is best to run.
#3 of 4 Gregg Loewen
Gregg Loewen
    Producer
  • 6,316 posts
  • Real Name:Gregg Loewen
  • LocationNew England
Posted November 10 2005 - 12:43 AM
use DVI
Have your cable box out put everything at 1080i.
Regards
gregg
The Sonodome - circa 2001
The Newest Sonotube - circa 2001
Gregg's DVDs updated...sometimes
Lion Audio Video Consultants usually current
#4 of 4 Allan Jayne
Allan Jayne
  • 2,406 posts
Posted November 19 2005 - 01:21 AM
If HDMI gives you a better picture than component, use one of the HDMI inputs. Theoretically HDMI can do everything DVI can do, and more.
Also, compare the quality of 720p shows converted by the cable box to 1080i versus sent as 720p to the TV.
Does your TV accept 1080p? If not you will never see all of the advantages of 1080p even though the display is 1080p. Unless your TV is one of the very few with advanced 1080i to 1080p conversion.
Video hints:
http://members.aol.c...ynejr/video.htm
