Jump to content
Help -- component to VGA connection problem
1 reply to this topic
#1 of 2 OFFLINE   Brian Perry
Brian Perry
  • 2,815 posts
Posted October 08 2005 - 01:37 PM
I recently upgraded my Escient Fireball music server to the new E2 model, which is almost identical physically, but they have eliminated the VGA output in favor of a component output (it still has composite and S-video jacks as well). On the previous model I was using the VGA output to connect to a Samsung 17" LCD monitor, which only has a VGA input. Everything was great.
When I saw the new model didn't have a VGA output, I bought a component to VGA cable, thinking that would solve the problem. According to the description of the cable, it would work on receivers outputting component Y-Pb/Cb-Pr/Cr (and the Escient outputs Y-CB-Cr). However, I'm getting no signal and I'm worried I'm going to have to lay out money for a new monitor that has component inputs.
Do I have the wrong cable or am I looking at buying a new monitor? I can't believe Escient would drop a VGA jack (probably for cost considerations) knowing that most of their customers use it to connect to LCD panels, if there wasn't an easy workaround. (Of course, I realize I should have checked all the specs before buying it.)
Thanks.
If it helps, here is the cable I bought: http://cgi.ebay.com/......MEWN:IT&rd=1
#2 of 2 OFFLINE   ChrisWiggles
ChrisWiggles
    Producer
  • 4,791 posts
Posted October 09 2005 - 05:07 AM
VGA in standard implementation is just RGBhv, while component is YPbPr, which are totally different signals. Some products will output YPbPr on a VGA plug, but you'll have to enable it in a menu somewhere. If this is not the case, you will need to purchase a transcoder to move between RGB and YPbPr.
