Jump to content
Sign up for a free account!
need help wiring three way crossover from PE
1 reply to this topic
#1 of 2 JoeGibs
JoeGibs
  • 110 posts
Posted September 22 2005 - 09:24 AM
i bought some three way crossovers from parts express. they can be found HERE
on the bottom, it has one connection labeled "M", then a set of three connections with the letter "C" above them, then another single connection labeled "W" and another single connection labeled "T". then on the top of the xover it has a single connection labeled "C" and another sincle connection labeled "IN".
little help?
#2 of 2 Brian Fellmeth
Brian Fellmeth
  • 792 posts
Posted September 23 2005 - 01:18 AM
"C" stands for common. So, the "in" and one of the commons go to the posts on the back of the box. Make sure you know which post goes to C for each box so you don't end up with a phase problem. Then the other three commons go to your drivers (one each) on the unmarked lugs. The marked (or +) lug are connected to T,M and W for tweeter, mid, and woofer respectively.
