Jump to content
Remote would help?
1 reply to this topic
#1 of 2 OFFLINE   Adam Sanchez
Adam Sanchez
  • 908 posts
Posted September 20 2005 - 08:16 AM
Hey all,
I recently setup my HT in my bedroom. The TV stand is right at the foot of my bed, with about a foot or so to walk by, so it's fairly close to the edge of my bed. So the problem is when I sit back on the bed to watch anything, the only way to have the remote hit anything is to hold it high up with my hand and angle it down the best I can. This does work... just wondering if there might be a better option?
Would a higher end remote, like a Harmony (which I have been wanting) help me out at all?
#2 of 2 OFFLINE   chris_everett
chris_everett
  • 403 posts
Posted September 22 2005 - 09:34 AM
Not to point out the obvious, but try replacing that batteries. Also, see if you can't do a "bounce shot" off of the ceiling or something.
--Chris Everett
